Old 05-15-2014, 10:00 PM   #1
C130NAV
C130NAV's Avatar
Drives: Whiteout 6Sp FR-S
Need help with boost control install.
Got a pnp boost controller from sbd and need to know where the hoses connect. I know one goes to the turbo actuator but where does the other one come from. When I look at the pictures in his thread it looks like it Ts off of the hose on the break booster but in the post it says hose off of turbo. If I connect to the actuator where does the hot side turbo barb hose connect. Pics would be awesome. Thanks.
Sent from my SPH-L710 using Tapatalk
C130NAV is offline   Reply With Quote
Old 05-16-2014, 02:10 PM   #2
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
the common ports (when you blow into one, the air comes out the other) go to the nipple on the turbo compressor housing, and the other to the wastegate nipple (internal wastegate im assuming). the 3rd port can just be left to vent to atmosphere. that configuration will run wastegate spring pressure with the controller unplugged. then you have the solenoid duty cycle tuned from there
DIY - Defi 60mm Boost Gauge Install in AC Vent msile DIY (Do-It-Yourself) Guides 55 02-27-2016 02:10 PM
Boost Control Basics pixel67 Forced Induction 2 06-06-2015 11:27 PM
Screencast: closed loop boost control with RaceRom jamesm Software Tuning 2 02-10-2014 03:23 PM
Ecutek boost control with ebcs help. gdrider77 Software Tuning 11 02-02-2014 10:06 PM
Guys running EcuTek boost control ATSAaron Forced Induction 14 09-14-2013 04:08 PM
