Old 05-08-2014, 09:04 PM   #1
FRStock
Drives: 13 FRS
Widest tire on 17x7?
Thinking about new wheels, some with a 50mm offest and others with a 42.
What's the widest tire I can fit on stock suspension? I'm thinking 235/40, even 245/40 if it fits. Probably Dunlop ZII's or Bridgestone RE-11s.
These will be for autox only.
FRStock is offline   Reply With Quote
Old 05-08-2014, 11:09 PM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
People in CS have done 245s
Old 05-09-2014, 02:26 AM   #3
renfield90
The Stig's German cousin
Correct. IIRC the Hoosier 245 needs the +42 offset but the street tire 245s can live on stock offset. +50 might be pushing it though. Regardless, why not maximize your track width?
Old 05-09-2014, 07:15 AM   #4
maxjedi
The Cloudmaker
maxjedi's Avatar
Drives: GT86, G37S
Tire manufacturers recommend 215 maximum for 7" wheel and 245 maximum for 8"
... my build thread: maxjedi's turbo "daily drifter" GT86 ...
maxjedi is offline   Reply With Quote
Old 05-09-2014, 07:25 AM   #5
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
An extremely stiff tire like the Z2 can do 235 or 245 on the 7". Something softer like an RS3 or any normal street tire (not competition level), I would stay with a 215.
Ive been running 235 Z2s, 215 RS3s and 215 daily tires for a while. I have effective offset of +47 and I can clear 245s on them (+50 with 3mm spacer). 245s will work on the Z2s, a few people are doing it but most are going 235s
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 05-09-2014, 08:34 AM   #6
TrqlessWonder
Drives: 2014 FR-S
I have 245/40 hoosiers on mine. My wheels are +42, and sitting in grid I can just squeeze a finger tip between the tire and the spring. Even on A6s, I think once you pass 235, you start getting diminishing returns. That is, the 245 puts down a bigger contact patch than a 235 will, but not the full extra 10mm.
When I go to street tires next season, I'll probably be on some flavor of 235.
With the right equipment, I've seen 275s on a 6" rim.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 05-09-2014, 08:59 AM   #7
FRStock
Drives: 13 FRS
I know everyone runs RPF1s but what about Kosei K1 TS? The OZ wheels are just too expensive but the K1s are even cheaper and lighter than the RPF1s.
Old 05-09-2014, 09:40 AM   #8
Kido1986
Dodging cones
Kido1986's Avatar
I run them, with a 3mm spacer.
Old 05-09-2014, 09:54 AM   #9
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
I'm using a 245/40 RS3 Version 2 on RPF1s for CS. No problems so far.
G_Ride is offline   Reply With Quote
Old 05-09-2014, 09:57 AM   #10
chucky12012
Drives: 2013 Asphalt Scion FR-S
I run the Kosei's, but I am using 225 tires. For me it's a cleaner fit and I can run the rears at lower pressures and the stay responsive and don't roll over. I think the majority run 235 though, which should still fit on the Kosei's, but I'd guess it would be close. 245 on the Kosei would definitely require a spacer.
chucky12012 is offline   Reply With Quote
Old 05-09-2014, 09:59 AM   #11
STV3
Señor Member
STV3's Avatar
225 is the widest I would go.
STV3 is offline   Reply With Quote
Old 05-09-2014, 10:30 AM   #12
Biggins
Drives: Yes
I run 225 Yokohamas which are wider than most/all other manufacturers in that size on Koseis +50. They fit fine, but I run a 5mm spacer now for peace of mind. I'll probably run 245 or 235 next.
Biggins is offline   Reply With Quote
Old 05-09-2014, 10:31 AM   #13
SeanRTR
C-Street AutoX
SeanRTR's Avatar
You sound like the robotic dude who refused to mount my 245's on 17x7's at Discount tire.
"The tire could fall off the rim and cause a serious accident!"
245's fit just fine on a 17x7 in the rear, and I haven't died yet.
Pictures here:
http://www.ft86club.com/forums/showt...t=41955&page=2
SeanRTR is offline   Reply With Quote
Old 05-09-2014, 11:11 AM   #14
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Domo arigato Mr. Roboto.
Widest tire to fit on an 18x9.5 Wheel?!!! ** ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 60 07-07-2014 04:08 PM
Whats the biggest/tallest/widest tire you have on 17/8 wheels? NickFRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 06-14-2013 09:36 AM
optimal street tire size for RTR on 17x7 hankster Tracking / Autocross / HPDE / Drifting 110 03-21-2013 12:40 AM
What is the widest tire for these wheels? ngabdala Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 09-12-2012 09:20 AM
Widest rear tire for a staggered setup? Jeff Lange Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 05-22-2012 08:52 PM
