Old 05-03-2014, 05:55 PM   #1
J-Money
J-Money's Avatar
Drives: GT-86
Metallic Rattling sound past 4k
So i installed an intake and got a ft86sf flash/tune not to long ago and about a week after that i hear a metallic buzz, Sounds like its coming from somewhere on the drivers side engine bay... over 4-5k rpm all the way up to redline
not noticeable in 1-2 gear but 3-6 u can hear it.. i rev it up in neutral and there is no sound so i know it cant be the intake.. its only when moving or when the torque kicks in i guess.. also took the metal heat shield off the bottom of the car to see if that was the problem and drove around and its still there.. it doesn't make noise if im in the 3k rpm range and going over bumps. i feel like its only under load
J-Money is offline   Reply With Quote
Old 05-04-2014, 03:12 AM   #2
humfrz
My guess is that the intake is "buzzing" up against something.
It may hit that something only when the engine twists a bit (torque), because it's under load.
So, I'd suggest you try to find where a part of the intake may be rubbing and stick something between those parts.
humfrz - jest guessing ....
Old 05-05-2014, 09:59 AM   #3
codesplice
Elite Recognized Geek
codesplice's Avatar
Drives: 2014 DGM BRZ Limited
^ I like the way you think.
If it was fine, then you changed something, and now it's not fine, always look first at the thing you changed
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+
codesplice is offline   Reply With Quote
Rattling Engine Noise (Video with sound) mystic Southern California 21 12-28-2013 04:11 AM
Torque dip sound: rattling / vibrating mike_ekim1024 Software Tuning 6 11-06-2013 02:17 PM
Why NA? Because it might be a thing of the past.. rice_classic Other Vehicles & General Automotive Discussions 20 10-07-2013 09:06 PM
BC Coilover failure in the past phenom86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 10-25-2012 05:07 PM
Is HellaFlush a thing of the past? RYU Off-Topic Lounge [WARNING: NO POLITICS] 67 10-13-2012 02:46 PM
