Old 05-01-2014, 08:28 AM   #1
SergeyAU
Drives: 86 GTS
Hi beam +ve wire location needed
Hi guys
I am installing a garage remote into my 86. Remote is all wired up and will either close or open my garage door when I flash my Hi beams.
Remote is ready, but I cannot find a +ve wire for the hi beams =(
I don't want to cut into hi beams wire in the actual headlight assembly, and was thinking that its just somewhere in a fuse box =( obviously not =(
Can someone please help me to identify a positive wire that is active when you flash your hi beams?
Thanks
SergeyAU is offline   Reply With Quote
Old 05-01-2014, 01:07 PM   #2
sshole
Take a look at the wiring diagram (link: "http: / / my - 86 . com/dl/BRZwiring.pdf" - remove the spaces), pages 148-156.
sshole is offline   Reply With Quote
Old 05-01-2014, 10:03 PM   #3
SergeyAU
Drives: 86 GTS
if I understood the diagram, I would not be asking =(
Do you guys know if there is a difference to where the cabling goes for the UK/AU cars?
Old 05-04-2014, 10:03 PM   #4
SergeyAU
Drives: 86 GTS
OK, update
Was too hard to search for the switch wires in the car, so installed it in the engine bay fuse box, getting the power from the Hi beam fuse. So far so good =)
Old 05-08-2014, 04:33 PM   #5
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
That is the correct location, the high beam fuses get powered by the relay in the fuse box that is next to them.
Scenic Driver is offline   Reply With Quote
Which wire is "Low Beam"? N1rve Cosmetic Modification (Interior/Exterior/Lighting) 14 05-12-2014 01:35 AM
Hi beam indicator Norkoastal BRZ First-Gen (2012+) — General Topics 4 12-10-2013 12:53 PM
Reverse light wire location? derka-derka AUSTRALIA 1 05-29-2013 09:19 AM
HID and high beam use gatorbushmen Cosmetic Modification (Interior/Exterior/Lighting) 4 04-19-2013 04:56 PM
Reverse Wire Tap wire Location? Norkoastal Electronics | Audio | NAV | Infotainment 2 10-19-2012 10:22 AM
