Old 04-16-2014, 11:32 PM   #1
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Which wire is "Low Beam"?
Hi All:
I have a 2013 10 Series FRS, I'm trying to install fog lights onto it. I watched the Diode Dynamic Video and in the video there is a red/black wire only. On my car, I have TWO REDs and ONE black.
I've googled search the wiring and it says Low Beam is Light Blue? Which I really don't think so.
Could someone tell me which wire to tap into? Whether it's the Red Wire with the Stripe, the Red Wire with Silver dot?
If I had a volt meter I would run a test, but I don't have one.
N1rve
Old 04-18-2014, 01:51 AM   #2
N1rve
N1rve's Avatar
Bummpppp.... Help?
N1rve
Old 04-18-2014, 01:17 PM   #3
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Hey wats up hopefully I can help. I too have a 10series and the way I tapped the wires was into the side marker lights. The black wire from the foglights are connected to the black wire in the side markers. The red wire from the foglights are connected to the white wire on the side markers. Best of luck on your install. Foglights would then run under the park lights.
Old 04-18-2014, 01:31 PM   #4
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
Originally Posted by N1rve View Post
Hi All:
You have to remember that that install is using a regular FR-S with separate low/hi beams. You have a 10 series that comes with a factory bi-xenon setup which is different. So like the previous poster suggested maybe use the side markers or contact diode and see if they have installed this on a 10 series already so they can tell you which wire to tap.
Rican_D is offline   Reply With Quote
Old 04-18-2014, 05:00 PM   #5
N1rve
N1rve's Avatar
So does that mean they only turn on with the parking lights? Or will they still turn on with the headlights?
Since black is ground, can't I just tap it to a screw?
I did talk to them and they said I can also tap into the side markers... I was a little confused from their message so I didn't wanna keep bothering them... LOL
N1rve
Old 04-18-2014, 05:25 PM   #6
FiRStsc10n
Canadian FR-S Member
FiRStsc10n's Avatar
Drives: FR-S '10 Series'
Parking lights stay on with headlights. But your fogs will also come on with parking lights if that matters to you.
From the picture it looks like you are going from the driver side?
The low beam is pin#5. I know it's thicker and red with a brown plug on the passenger side. This is confirmed because I wired my resistor to it. I'm not 100% on driver side, The colors seems to differ on the driver side so I suspect (logically) it is the thick teal one with brown plug.
FiRStsc10n is offline   Reply With Quote
Old 04-18-2014, 05:48 PM   #7
N1rve
N1rve's Avatar
Sounds like tapping into the side marker is a lot easier than the headlight. I'll poke around my engine bay later today.
N1rve
Old 04-18-2014, 06:00 PM   #8
FiRStsc10n
FiRStsc10n's Avatar
Probably so. I hear a lot of people tapping into the Sidemarkers with the diode kit. Let us know how it goes and installed pics.
Old 04-18-2014, 06:58 PM   #9
NyC Zn6
NyC Zn6's Avatar
Yes they will come on with park lights. Keep us posted hope it will be an easier install for you by tapping into the side markers. If it helps I also purchased the Diode Dynamics kit which is awesome for the price.
Old 04-18-2014, 08:04 PM   #10
Zen86
Run, Reach, Fly
Zen86's Avatar
Drives: Monogram Firestorm
Op the solid blue wire in your picture is the low beam. The Brown under that is your led.
In the passenger side solid red is low beam, Brown is led.
Tap into the blue if you want fogs to come on with your low beams.
Zen86 is offline   Reply With Quote
Old 04-18-2014, 10:56 PM   #11
N1rve
N1rve's Avatar
Is the side marker harness the loom that goes under the light harness?
Is it the red one I'm looking at?
The solid red? On the connector on the left (with like 5 wires?)
N1rve
Old 04-19-2014, 01:08 AM   #12
Zen86
Run, Reach, Fly
Zen86's Avatar
^ yep that's the low beam. I'm guessing this is a shot of your passenger side?
Old 04-20-2014, 05:13 PM   #13
N1rve
N1rve's Avatar
Yes it is.
N1rve
Old 04-20-2014, 07:30 PM   #14
Zen86
Run, Reach, Fly
Zen86's Avatar
How's the install? Got it to work?
Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? davidchoi Cosmetic Modification (Interior/Exterior/Lighting) 49 11-22-2014 10:17 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
