Old 04-29-2014, 08:36 PM   #1
c4thsaltminer
c4thsaltminer's Avatar
Drives: 2013 ScionFR-S
Going to larger wheels
Ok, I'm sure this has been covered on here somewhere but I can't find it. Back in the day when we used to put taller tires on our muscle cars we always had to try and find the proper gear to replace in the tranny so the speedo would read correctly(or when changing rear diff gearing). If I put larger rims and taller tires on my FRS to fill our the wheel wells, is there a way to program that to the speedo so it reads correctly? If so how?
c4thsaltminer is offline   Reply With Quote
Old 04-29-2014, 08:39 PM   #2
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
Why would you go with larger tires in the first place...typically you want to stay the same height...or damn close
Fett4Real is offline   Reply With Quote
Old 04-29-2014, 08:42 PM   #3
Mikem53
Drives: FR-S 6MT
You are going to lose acceleration with larger/taller sized wheels and tires.. Smaller wheels and tires will effectively lower the final gear for better accel..
I think the speedo will be fine as it's calculated at final drive.
Mikem53 is offline   Reply With Quote
Old 04-29-2014, 08:51 PM   #4
c4thsaltminer
I've always liked the way they look when it fills the wells a little more, but I don't think I want to lower the car any(afraid of going over speed bumps now). Been looking at to many custom/tuner mags, like the look of 19' & 20" rims :-)
Old 04-29-2014, 08:58 PM   #5
frslee
Just drive it
Drives: 13' FR-S
So... you want to replace gear in transmission just to run larger diameter wheels?
frslee is offline   Reply With Quote
Old 04-29-2014, 09:02 PM   #6
PEWPEW
PEWPEW's Avatar
Drives: 10 Series FRS
You should honestly be fine with maybe some springs and 18 inch wheels with maybe 225/40. I'm lowered on coilovers with filled wells and have no problems with speedbumps. There is a whole bunch of clearance.
If you went with 19 or 20 inch rims WITH larger tires I think you'll look like this lol:
Check out the build thread!
PEWPEW is offline   Reply With Quote
Old 04-29-2014, 09:02 PM   #7
c4thsaltminer
No, I just want my speedo to read correct if I go to a taller wheel. 30 years ago when I used to play with cars, we'd have to change the input gear at the tranny if you made a gear change or tire change so the speedo was correct. Because everything is electronic, I'm guessing there's a way to change the programming to compensate. Having a new car is making me feel old!!!
Old 04-29-2014, 09:06 PM   #8
fatoni
im pretty sure that nobody so far in this thread has a very good understanding of the concepts at play. i think the bottom line is that its a pretty bad idea. check the suspension forums or build threads. i think you might like the way the oem outer diameter fills the wheel wells once the car is lowered and its a much more hassle free process that can provide benefits outside of aesthetics with minimal downsides.
Old 04-29-2014, 09:09 PM   #9
c4thsaltminer
Thanks, You're probably right! I just checked out your build, nice job. Those rims/tires are the sort of look I'm going for. Your car sits VERY nice
The Following User Says Thank You to c4thsaltminer For This Useful Post:
PEWPEW (04-30-2014)
Old 04-29-2014, 09:45 PM   #10
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
I think you bought the wrong car for this...
The Following User Says Thank You to Turbo95eg6 For This Useful Post:
Mad1723 (04-30-2014)
Old 04-29-2014, 09:54 PM   #11
FlamingRectumSyndrome
Shriveled Old Member
FlamingRectumSyndrome's Avatar
Drives: 14 Hot Lava FR-S
Typically when you go to larger wheels, you go with lower-profile tires so the overall diameter doesn't change much, leaving the gearing and speedometer accuracy essentially unchanged.
That said, larger wheels work to your detriment, at least until you start making another 50+ horsepower. You might find this interesting:
http://www.ft86club.com/forums/showthread.php?p=1705948
So, what's more important-- looks, or how well your car performs/corners/drives?
FlamingRectumSyndrome is offline   Reply With Quote
Old 04-29-2014, 09:54 PM   #12
TStafford
TStafford's Avatar
Drives: 2015 FR-S Ultramarine Metallic
http://www.tacomaworld.com/forum/tir...5r18-235-35r18
Does this help?
TStafford is offline   Reply With Quote
Old 04-29-2014, 09:58 PM   #13
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
18"s will fill the wheel well quite nicely. Take a look around at other peoples' cars like suggested and come to your own conclusion. Also, 18"'s won't set the speedometer off by any noticeable amount.
Jyn is offline   Reply With Quote
Old 04-29-2014, 10:26 PM   #14
Tromatic
Is there an FR-S Donk yet?
Tromatic is offline   Reply With Quote
The Following User Says Thank You to Tromatic For This Useful Post:
Thrustin (04-29-2014)
Larger Rotrex Supercharger FAER Forced Induction 13 03-18-2014 02:47 AM
Will there be a larger TRD aftermarket and When? corvino26 Scion FR-S / Toyota 86 GT86 General Forum 17 12-10-2012 04:22 PM
Larger Avatar Vote? Neekowahhhh Site Announcements / Questions / Issues 7 07-25-2012 08:05 PM
FRS is barely larger than a Miata? stlgrym3 Scion FR-S / Toyota 86 GT86 General Forum 20 02-14-2012 01:36 PM
Larger Rear Wheels - Tacky or Acceptable? Orly Scion FR-S / Toyota 86 GT86 General Forum 33 02-28-2010 11:16 PM
