Old 04-28-2014, 07:41 PM   #1
xrinnenganx
Drives: 2013 Scion FR-S Raven
DiodeDynamics Lights?
Sup guys!
So, I ordered from DiodeDynamics, and got the multicolored prism bulbs as well as the fog light kit, so I can put the prism bulbs in place of the fog light bulbs. Has anyone done this? I can't seem to figure out how to swap the bulbs, and I definitely don't wanna mess anything up! Any help would be greatly appreciated!
xrinnenganx is offline   Reply With Quote
Old 04-28-2014, 08:03 PM   #2
Chimera
Drives: FRS
funny, I'm working on a similar project, interest to see, seeing as I don't actually have fog lights yet.
Old 04-28-2014, 08:14 PM   #3
xrinnenganx
I'll definitely post up pics once I got it all installed and working, but I gotta figure out this issue first!
Old 04-28-2014, 11:19 PM   #4
jonzhuxD
Drives: Ultramarine FR-S
Originally Posted by xrinnenganx View Post
Sup guys!
Assuming both your fog kit and your prism bulbs are H11 bulbs (should be on your invoice) then just take out the fog light bulb by turning it counter clockwise and disconnecting it from your wiring harness and replace it with your prism bulb and turn it clockwise to secure it, literally plug and play.
jonzhuxD is offline   Reply With Quote
Old 04-29-2014, 07:33 AM   #5
xrinnenganx
Yea they are the same build size. And that's what I was thinking to do too! So I pretty much take the prism bulb and put it in place of the fog light bulb, and I have to disconnect the fog light bulb by (I'm assuming just twist it off the wiring harness?)
Old 04-29-2014, 07:58 AM   #6
jonzhuxD
To take the bulb out you just grab it and turn it counterclockwise and pull it out. To disconnect the bulb from the foglight harness you press down on a clip and wiggle it out. The harness should look like this.
The top of that is where the clip clips into, on the harness side, press down on there and it should come out with a little wiggling
Old 04-29-2014, 08:06 AM   #7
xrinnenganx
Dude thanks so much! I'll be trying this as soon as I can!
Old 04-29-2014, 10:59 PM   #8
Chimera
Drives: FRS
got my fog lights in today, eyeballing the h11 and the prism I'm guessing that the orange O ring on the prism holds it in place, mine at least definitely doesn't have the same 3 mounting point. its late and I don't feel like accidentally breaking things, I might try putting tab A into slot B (hahah, but I mean the light and fog light housing) tomorrow
Old 04-29-2014, 11:11 PM   #9
Chimera
Drives: FRS
maybe I ordered the wrong thing?
the photo on the site looks like it has h11 braces
(photo pulled from http://www.diodedynamics.com/store/l...-drl-leds.html and is not my property)
mine looks like the other photo:
Edit: ( may have the HP8? wonder if OP has this as well?)
Old 04-29-2014, 11:27 PM   #10
Chimera
Drives: FRS
I did order the wrong bulb.
this link takes you to the H11 version for use in fog light application
http://www.diodedynamics.com/store/l...led-bulbs.html
edit:
maybe ill keep them.. gonna sleep on it.
Old 04-30-2014, 12:09 AM   #11
jonzhuxD
PM @DiodeDynamics, I'm sure they'll be able to help you out, Nick and his team have excellent customer service.
**PHASTEK** HID Headlights, Reverse Lights, Fog Lights (FR-S / BRZ) PhastekSport Exterior Parts - Lighting 18 07-09-2014 07:42 PM
DiodeDynamics Door LED install Khazzy DIY (Do-It-Yourself) Guides 25 05-09-2014 09:52 PM
FS: OEM FR-S head lights with HID and Tail lights chimmy Exterior Parts (Aero, Lighting, Etc.) 7 03-25-2014 07:57 PM
Led Daytime Running Lights to Fog Lights conversion? mfbmike Cosmetic Modification (Interior/Exterior/Lighting) 1 08-24-2013 07:47 PM
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 08:38 PM
