Old 04-17-2013, 09:20 PM   #1
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
DiodeDynamics Door LED install
"THESE ARE NOT OFFICIALLY" Door LED's but the Trunk LED's. I am not saying DiodeDynamics is selling these as Door LED's but I got a tad creative on the thinking side figuring out they were the same bulb. Anyways, I hope this brings them some good revenue seeing how you can now get a complete LED package for the BRZ. They are priced VERY well and shipping is phenomenal! So fast! Reward program they have is great. I got 5 dollars off my last order.
In this install guide I used the STAGE 2 LED. To me they are not over bright but are SUBSTANTIALLY brighter than stock bulb.
Anyways on to the review and DIY.
Take small flat Head screw driver (or plastic trim removal tool) and find the wider gap area of the plastic cover. Driver side was on the bottom, passenger was on the top so opposite sides.
Pry it open to reveal this. Drivers side clip has less wiring to play with so be careful not to rip out the green wires connected to the gray plug. This plug has a small depression point on top to remove the plug from the plastic cover. Press where the screw driver in the picture is pointed at and ease it away from the cover. Do not yank away.
Once you unplug it, look inside of the cover. There is 2 halves to the cover. The smaller half (the side that resides inside the door) has 2 depression points to release the bottom of the cover. First one you need to depress is the large one pointed at with the screw driver below and make sure it remains depressed by pushing it down a little.
The flip it around and depress the smaller one on the opposite side like so.
You can now separate the two halves.
Remove the stock bulb CAREFULLY! It is in there pretty good. I pushed it out with my thumb. It will be a little harder to get out if you have larger fingers but just wiggle it out.
Once it is out, replace with the DiodeDynamics Trunk LED. You will notice a plastic stop on the connector portion. Do not worry, it is still seated correctly and will have power going to the LED.
Now before you put the two halves together, be sure to plug the connector inside the door back in to make sure it powers on correctly.
If it does, you can just assemble the other half and put back in the door.
There you have it! About 10 minutes of work for much brighter areas to step in at night! Plus the white LED is much better than stock lighting.
Old 04-17-2013, 10:05 PM   #2
Diode Dynamics
Diode Dynamics's Avatar
Thanks for posting! That is the exact same door light assembly used in the 2013 Camry and Tundra, which we have tested here and that means we know EXACTLY which lights will fit it best. We'll have the BRZ door LEDs listed on on our site shortly.
The specific bulb you used would be considered a stage 2 brightness-level replacement. Thanks again! Shoot us an email and I'd be happy to get you an extra pair for your efforts.
Paul
Old 04-17-2013, 10:46 PM   #3
sklimo
I love @Diode Dynamics. Ordered twice from them and nothing but great things to say about them. That being said I want them. PM'd email
Old 04-18-2013, 01:51 AM   #4
Xdragonxb0i
Drives: ex500r
so it makes if fuction side door, that will be good when will it be available.
Xdragonxb0i is offline   Reply With Quote
Old 04-18-2013, 07:51 AM   #5
Khazzy
Khazzy's Avatar
If you want to do what i did they are available now. Just buy 2x trunk LEDs, one for each door. These are stage 2 bulbs
Old 04-18-2013, 03:03 PM   #6
jazztennor
jazztennor's Avatar
Drives: Scion FR-s
you guys need to make a set that will work on the frs. I will so be done for all the wiring and everything done already all i have to do it run it to the dome light
Upgrades
EVO 3 Exhaust,Emblem swap,Full Carbon Interior,Greddy intake
jazztennor is offline   Reply With Quote
Old 04-18-2013, 06:06 PM   #7
Khazzy
Khazzy's Avatar
A set in the door? I did not know yall had door lights. These should work as well. They sell FRS LED packages
Old 04-18-2013, 06:53 PM   #8
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
we don't have door lights. i've used the same ones from these guys to wire up door lights and they look great.
phanguy is offline   Reply With Quote
Old 04-18-2013, 08:45 PM   #9
Diode Dynamics
Hey guys, just to let you know, we have some product coming out soon that you all will be very interested in, Especially if you like door lights/courtesy lights. Stay tuned.
-Garrick
Old 04-18-2013, 09:02 PM   #10
Yruyur
Yruyur's Avatar
-Garrick
Get some 194 switchbacks
Old 04-19-2013, 10:26 PM   #11
jazztennor
jazztennor's Avatar
Drives: Scion FR-s
ya the frs doesn't come with the door lights. Thats what im saying sell a full kit for the frs
Upgrades
Old 04-22-2013, 07:50 PM   #12
zuldajin
zuldajin's Avatar
Drives: K24 Swapped FRS
-Garrick
My guess is LED-lit door sills.
zuldajin is offline   Reply With Quote
Old 04-22-2013, 08:05 PM   #13
dawnst3ar
Drives: 2013 MT FR-S Asphalt
Please Please Please!!!
dawnst3ar is offline   Reply With Quote
Old 05-02-2014, 11:07 AM   #14
IShift
Drives: 2014 Subaru BRZ
Just out of curiosity where did you get the housing for it i want to replace the red stock ones.
IShift is offline   Reply With Quote
DIY: APR Door Mirror Install RallySport Direct DIY (Do-It-Yourself) Guides 53 04-26-2019 03:08 PM
EOI - TRD Door Stabilizer kit AL008 AUSTRALIA 2 02-28-2013 02:21 AM
8's in the door cruzinbill Electronics | Audio | NAV | Infotainment 2 01-26-2013 05:10 PM
Anyone install door stabilizer? russv Cosmetic Modification (Interior/Exterior/Lighting) 1 08-12-2012 12:08 PM
