Old 04-28-2014, 07:18 PM   #1
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
FRS started funny
So this morning (after sitting for a day and a half) I started the car and heard it start funny. Usually it starts up and it's rumble rumble rumble.
This morning the car sounded like it skipped a beat. Like for a split second the rumble was gone and then the sound comes back.
It sounded like it had a hard time idling. Sort of like choking a motorcycle. I checked the dash no needle jumping and no CEL. It had a big gas smell outaide .
Would had gotten a sound clip but it went away after the RPM dropped.
I just started the car a few minutes ago after letting it sit for 6 hours. That sound did not return.
Should I be concerned? Anyone encounter this? Sign of DI failure?
Car is a 2013, made august 2013. Bought Dec 2013. Stock tune. Stock exhaust. Stock everything.
N1rve
Old 04-28-2014, 07:48 PM   #2
strat61caster
strat61caster's Avatar
Reminds me of this thread:
http://www.ft86club.com/forums/showthread.php?t=22351
I've gotten a hiccup a few times and a long start here or there. The two things I can think of are either turning the key too fast doesn't allow the fuel system to prime or maybe there's some flooding or an anomoly with the injectors depending on the shut down conditions.
Dealerships don't do jack shit without a CEL code and I haven't heard any grumblings of anything so I'd say your fine unless you can repeat it.
ineedyourdiddly
Old 04-28-2014, 09:11 PM   #3
N1rve
N1rve's Avatar
I think turning the key too fast would only be logical if I had a key to turn. Forgot to mention I have push to start. 10 Series FRS. auto.
N1rve
Old 04-28-2014, 09:26 PM   #4
strat61caster
If I'm not mistaken you can still push the button in a way to start the car before the accessory systems are given adequate time to power up.
But I don't know any better, quick googling found that you're supposed to wait for a green light but I'm sure you've come across it as well.
Like I said, dealership probably won't do anything unless you can replicate it or have an engine code. Best of luck.
ineedyourdiddly
Old 04-28-2014, 10:41 PM   #5
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
When I went to demo an FR-S one time, the car was idling terribly when we turned it on like you described. I'm sure it had been sitting for a few weeks though.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 04-29-2014, 01:21 AM   #6
N1rve
N1rve's Avatar
Thanks! Hope it's nothing serious.
Wonder what that could be.
N1rve
Old 04-29-2014, 02:16 AM   #7
humfrz
Like said ..... I reckon it just hiccuped ..... I wouldn't worry about it ....
humfrz
Old 04-29-2014, 02:56 AM   #8
N1rve
N1rve's Avatar
humfrz
Let's hope so Mr. Humfrz.
N1rve
Old 04-29-2014, 04:01 AM   #9
Luis_GT
Normal... mine does it every now and then since new...
Old 04-29-2014, 04:23 AM   #10
cpnslow
cpnslow's Avatar
Drives: 2013 Subaru BRZ Limited (WRB)
Same here... I've heard it about 5 times since new, had my car for about 6 months. Doesn't sound like anything abnormal.
My Build Thread: Nick's BRZ - "CPN SLOW"
My Car Photography: www.ngphotog.com
cpnslow is offline   Reply With Quote
Old 04-29-2014, 05:29 AM   #11
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
My car has started "funny" a few times.
My OB-LINK comes up with error code P1604 - "startability". If you have a friend with an ELM327 and the torque app or a friendly dealer you could check.
There's a few threads if you search P1604 on the forum and on the net.
I think the code clears after the car starts ok a certain number of times or I just get the code cleared when I go to the dealer. Doesn't seem to be an issue.
nzer is offline   Reply With Quote
Old 04-29-2014, 03:21 PM   #12
N1rve
N1rve's Avatar
So you actually get a CEL? I didn't get a CEL for my situation though.
I did a search and it's when people's car failed to start. My car didn't fail to start, it just idled funny like if the sound disappeared for a moment.
Normal Sound would be: _/-\_/-\_/-\_/-\_/-\_/-\_/-\_/-\_/-\_/-\_/-\
But this start up was like _/-\_/-\_____/-\____/-\_____/-\_/-\
Update 4/29/2014:
It was a nice 70 something degrees this morning, upon start up car idled fine but still had a very big gasoline smell. Usually don't have strong gasoline smell.
N1rve
Old 04-29-2014, 05:08 PM   #13
nzer
nzer's Avatar
Update 4/29/2014:
No, didn't get a CEL. Just an error code P1604 if looking through the diagnostics.
Sounds like a different issue though as mine is when engine turns over a bit more before starting rather than rough idle. There's a few threads on rough idle if you search that. There was even a TSB on it for the early builds - see under the BRZ ones here http://www.ft86club.com/forums/showthread.php?t=21868
Old 04-29-2014, 09:11 PM   #14
N1rve
N1rve's Avatar
I thought that TSB was for an Idle dip as if the car was about to stall? I didn't have a dip on my visual needle.
N1rve
Started my car and... zephyr69 Issues | Warranty | Recalls / TSB 8 07-15-2013 03:55 PM
The shopping has started! Captain Snooze AUSTRALIA 6 12-14-2012 05:19 PM
Anyone else started thinking about mods already? S2KtoFT86 Scion FR-S / Toyota 86 GT86 General Forum 108 09-14-2010 05:12 PM
