Old 04-25-2014, 08:25 AM   #1
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
ATEQ QuickSet TPMS tool
I attempted to use this last night to retrieve my stock wheels sensor IDs from the ECU. I successfully get through the PC part of the process, but when I connect it to my cars OBD port, the green light flashes as it should, but when I press the winter button (as the instructions say to read the codes from the ECU) I get a solid red led instead of solid green (as the instructions say I should get). Their FAQ says it's a software update that is needed but that didn't work.
I've tried the software and drivers from both the included CD and from their website. Surprisingly, the latest beta on their site did not have the BRZ as a vehicle option while the CD software does, which I assume is older.
Has anyone else had this issue? What's the fix?
Old 04-25-2014, 08:40 AM   #2
aschnell
I had issues reading out codes if I didn't wait for the ignition to fully come on. On the pc side no real issues. My pc does have some flaky USB ports so I had to use the right one.
aschnell is offline   Reply With Quote
Old 04-25-2014, 09:51 AM   #3
B-R-Z
B-R-Z's Avatar
Ok, so you're thinking give the ECU more time to boot?
I did leave it connected and re-tried the winter button multiple times with no success.
Old 04-25-2014, 03:41 PM   #4
aschnell
I think if I didn't wait long enough I had to go through the cycle all over. But you may need to get the update and get the pc software working first.
Old 04-25-2014, 08:17 PM   #5
B-R-Z
B-R-Z's Avatar
Turns out I was not waiting long enough between turning on the ignition and connecting the quickset device. I also tried first having the obd cable connected securely to the car and then connecting the quickset device to the other end of the cable to ensure a solid connection. Not sure which did the fix but it's working.
FS: ATEQ Quickset TPMS flashing tool abutterman Wheels and Tires 3 03-27-2014 12:34 PM
Tirerack TPMS ATEQ Quickset Issue aschnell Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 03-06-2014 11:38 AM
Has anyone tried ATEQ TPMS Quickset for our cars? pheoxs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 11-29-2013 03:26 PM
ATEQ Quickset help? brsaresmgs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 11-24-2013 12:58 PM
Anyone use an ATEQ TPMS Quickset? Foobar Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 04-06-2013 12:59 AM
