Old 04-24-2014, 12:50 PM   #1
karate_champ20
Drives: 13 whiteout FRS
suspensions noise after spring instal UPLOADED VIDEO
I have searched through about 5 pages of "clunking,random suspension noises" and have yet to find anything dealing with what I have going on.
Long story short, Installed Sportlines. When taking off from about 6-7mph to 12-13mph I hear a tinging noise. If I stay consistently inbetween those speeds I hear ting ting ting. It sounds like metal on metal.
I re-tightened all bolts to spec, jacked the car up and the wheels spin freely without any noise. Put the car back on the ground, left it in gear(so it wont move too far...) and moved the car forward and backwards and I could slightly hear it when all the way forward and the spring compressed slightly.
Any input or knowledge will be appreciated greatly!
Youtube video of sound
karate_champ20 is offline   Reply With Quote
Old 04-24-2014, 12:59 PM   #2
wparsons
wparsons's Avatar
A few possibilities...
Are ALL the bolts tight? Sway bar endlinks, control arm bolts, etc?
Did you reassemble the struts/shocks correctly? The fronts have to be assembled carefully to get the upper spring seat on the strut shaft correctly. If it's not on properly when you tighten the upper nut it can move around and make noise.
Are your swaybar endlinks hitting the control arm?
flickr
Old 04-24-2014, 01:01 PM   #3
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
just verifying: were the control arms torque to spec with the suspension loaded?
supramkivtt2jz is offline   Reply With Quote
Old 04-24-2014, 03:59 PM   #4
karate_champ20
I will go over everything again tomorrow.I torqued them when the car was lifted up(no load). I made sure the springs were seated correctly. I forgot to mention, Its the rear.
Old 04-24-2014, 05:11 PM   #5
wparsons
wparsons's Avatar
It's not just the springs that have to be seated correctly, the upper spring seat on the front has to be seated on the strut shaft correctly as well. It's really easy to put it together not seated, even with the spring seated properly in the upper seat.
The strut shaft is stepped, and the upper spring seat has to fit onto the stepped part properly to work right.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
karate_champ20 (04-24-2014)
Old 04-24-2014, 05:12 PM   #6
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
What method did you use to remove the upper strut hat?
Old 04-24-2014, 07:46 PM   #7
karate_champ20
I Used a spring compresser, and sockets, with an allen holding the shaft
Old 04-24-2014, 08:33 PM   #8
Malt
Drives: 2015 WRX
Is your dust shield hitting the rotor? I somehow managed to bend mine to where it made contact with the rotor when I installed my coilovers. It made a terrible metal on metal sound until I bent it back.
Malt is offline   Reply With Quote
Old 04-24-2014, 09:37 PM   #9
Wepeel
Drives: '13 BRZ Ltd
This also sounds like symptoms of an impending CV failure...
Wepeel is offline   Reply With Quote
Old 04-25-2014, 02:54 PM   #10
karate_champ20
just an update. went back through everything today. took the rear shocks out and put them back in, made sure everything was seated correctly. torqued everything to spec. still making that noise. I can hear the noise is coming from the right rear. Still only from about 7mph to 12-13. I also checked the dust shield was bent. that part is fine
Old 04-25-2014, 03:02 PM   #11
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Mine did that after spring install, went away soon as I tightened everything some more when it was under load
Old 05-02-2014, 06:34 PM   #12
karate_champ20
Checked all bolts on the control arm, torqued bolts under load. Took the caliper and rotor off to make sure everything was looking normal... still have no found the problem.
Heres a vid of the sound its making!
Old 05-04-2014, 08:05 PM   #13
karate_champ20
problem solved. I have rpf1's. One of the bolts came off the valve stem and is floating around in the wheel.
thanks for any and all help
Tips for taking off front bumper for BRZ to instal Perrin Cai? Oburn Engine, Exhaust, Transmission 10 07-08-2015 09:28 AM
Clear bra before or after lip instal Turbo95eg6 Cosmetic Modification (Interior/Exterior/Lighting) 0 02-26-2014 12:56 PM
Post you Turbo instal pics! FastLane1000 Forced Induction 13 07-24-2013 07:42 PM
Any air suspensions? Danny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 06-16-2013 11:56 AM
BRZ suspensions Subabie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 03-18-2013 01:56 PM
