Old 07-10-2013, 01:25 PM   #1
Oburn
Drives: 2013 Subaru BRZ
Tips for taking off front bumper for BRZ to instal Perrin Cai?
Looking for some tips to make the process of taking the front bumper off of my BRZ to instal CAI, any would be appreciated thanks
Oburn is offline   Reply With Quote
Old 07-10-2013, 01:28 PM   #2
Propaganda
Diamonds & Cadillacs
Drives: '13 fr-s, 1974 911s
I can't remember the thread title, but its in the DIY section. Darren did a DIY for headlight blackouts, and that's how it starts out. Just do a Google search for frs or brz front bumper removal. Hardest part is getting the sidemarkers out. Other than that, its a breeze
Propaganda is offline   Reply With Quote
Old 07-10-2013, 01:40 PM   #3
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
http://www.ft86club.com/forums/showthread.php?t=8788
shiumai is offline   Reply With Quote
Old 07-10-2013, 01:55 PM   #4
Oburn
Ok thanks a lot guys
Old 07-11-2013, 02:15 PM   #5
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
I never took off my bumper to install my CAI, I just unbolted the top portion of the bumper and that allowed enough space to squeeze the pipe and the intake to where it needed to be.. the only difference is you have to take off the frame that holds the hood to give clearance for the intake.
LeeMaster is offline   Reply With Quote
Old 07-11-2013, 05:43 PM   #6
FT86Dubai
FT86Dubai's Avatar
Drives: 2013 Toyota 86
approximately how much time did that save you?
2013 Toyota 86 (Sold it and regretting)
FT86Dubai is offline   Reply With Quote
Old 07-01-2015, 04:58 PM   #7
KungFuWaffle
KungFuWaffle's Avatar
Drives: Whiteout
Sorry for the revival of the old thread, but if you don't mind, can you show me which bolts you removed and how to pull the bumper slightly to put it on?
KungFuWaffle is offline   Reply With Quote
Old 07-01-2015, 05:17 PM   #8
phrosty
Bumper removal is scary the first time but it is actually very simple. Unbolt it, pull it off, push it back on, bolt it back up. Check out this SpecD Tuning Headlight install video. They show each step:
[ame]http://www.youtube.com/watch?v=mMdIWZLUEj0[/ame]
People get by without removing it for the install, but I don't think you'll be able to change the filter later on without removing either the bumper or the whole intake.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 07-06-2015, 12:28 AM   #9
LeeMaster
Red wine
There are two bolts on top (Arrows marked location on picture).
And then there are two more bolts on the bottom, if you look at the crank pulley, the two bolts are just right across from it, you wont miss it. Once you take the bolts off the frame which holds the hood, it should easily come off. It's super lightweight so this can all be done without needing someone else to help out.
Now all you have to do is just carefully guide the installed filter + intake pipe to the desired location. Once you do so, just reinstall the frame and youre good to go. No worries about worn front bumper retainers whatsoever. Hope this helps.
Old 07-08-2015, 09:08 AM   #10
iamdaspoon
iamdaspoon's Avatar
Drives: 2015 Subaru WRX
I'd recommend getting one of those little plastic remover tools, I wound up breaking a lot of those fakeish threaded plastic bolts. Harbor freight has them cheap
iamdaspoon is offline   Reply With Quote
Old 07-08-2015, 09:28 AM   #11
DarkSunrise
DarkSunrise's Avatar
Once you get the side markers out, it's pretty easy. Just take your time and don't force anything.
2022 BRZ Build
2013 FR-S Build
Taking off bumper without damaging side markers Ericfrs DIY (Do-It-Yourself) Guides 7 06-17-2017 09:05 PM
DIY- Perrin Oil Cooler/ Bumper removal notes Splat DIY (Do-It-Yourself) Guides 30 08-27-2014 01:12 PM
Perrin Slash Cut Exhaust Tips Chillz Engine, Exhaust, Bolt-Ons 6 06-22-2013 01:23 AM
FS: 4" Perrin Slash cut stainless steel exhaust tips aqua8701 Engine, Exhaust, Bolt-Ons 5 05-11-2013 04:31 PM
Perrin Front Front LCA Bushes Zero Offset SOLD Captain Snooze Australia Classifieds 0 05-05-2013 04:14 AM
