Old 04-22-2014, 09:43 PM   #1
TONYpepperon1
TONYpepperon1's Avatar
Drives: 2013 CBS BRZ
ST Coilovers
Hey guys. I'm just wondering if anyone here is running ST coilovers all year round. Specifically people in areas that see a cold snowy winter (i.e. tri state area). I know that because of there galvanized steel, they're much more prone to rust. Anyone have any serious issues with rust or seizing?
Sent from my SAMSUNG-SM-G900A using Tapatalk
TONYpepperon1 is offline   Reply With Quote
Old 04-23-2014, 12:16 PM   #2
Dpforlife
Dpforlife's Avatar
Drives: Scion FR-S Raven
Wondering the same thing!!
Dpforlife is offline   Reply With Quote
Old 04-23-2014, 12:30 PM   #3
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
from what ive seen, the VW guys that have been running ST for a few years havent really had any issues(in the colder areas)
As with any coilover, be sure to wipe down the threads when you rotate tires and such.
But bump for someone with direct experience with this!
The Following User Says Thank You to continuecrushing For This Useful Post:
TONYpepperon1 (04-23-2014)
Old 04-23-2014, 11:03 PM   #4
Zero90
Zero90's Avatar
Drives: "14 BRZ Limited - SWP
Had my ST coilovers installed during the snowy/cold as f**k winter here in VA and never had any issues. Only had them on for about two-three months now. Still going strong and settled in pretty well.
Zero90 is offline   Reply With Quote
Old 04-23-2014, 11:04 PM   #5
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
Was reading somewhere that you could spray them with some Amsoil sealant to keep them from rusting
Fett4Real is offline   Reply With Quote
The Following User Says Thank You to Fett4Real For This Useful Post:
Jive Turkey (04-24-2014)
Old 04-24-2014, 12:51 AM   #6
TONYpepperon1
Did you put any protective coating on them?
Old 04-24-2014, 12:52 AM   #7
TONYpepperon1
Yea I also heard about this stuff that Boeing made but I don't know much about it.
Old 04-24-2014, 07:41 AM   #8
Dpforlife
Dpforlife's Avatar
I found a DIY on another site that stated use something called POR-15 and using anti-seize lub
Old 04-24-2014, 01:07 PM   #9
TONYpepperon1
Can you throw that link in here.
Old 04-24-2014, 02:58 PM   #10
Zero90
Zero90's Avatar
That, Im unsure. I had Ptuning install them.
Old 04-24-2014, 03:16 PM   #11
congee
congee's Avatar
Drives: SSM BRZ
I'm thinking of getting the ST coilovers too but live in salt city(Toronto, Canada). I don't mind rust proofing it every season since I switch tires every winter season. Would I need to take the whole coil over apart or can I just spray it down with rust check or corrosion free?
congee is offline   Reply With Quote
Old 04-24-2014, 03:30 PM   #12
Dpforlife
Dpforlife's Avatar
Yeah no problem I didn't know the rules about linking another forum on here.
http://forums.vwvortex.com/showthread.php?4196000/page1
Old 04-24-2014, 03:31 PM   #13
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
like i said in the PM...there are coating you can apply to keep them safe.
also, power washing salt is a must.
can also do these, contact @Overland Designs :
Originally Posted by Overland04 View Post
After my last coilover cleaning I decided to take some of the ideas that I have seen from members here and good old Google to help create this quick mod to my car.
Here are more mods on my build thread HERE.
It uses Denier, a polyurethane coated nylon material and is stitched with Velcro and 1/4" shock cord. It's washable, waterproof and mold resistant.
Besides the sewing machine, the materials I used were:
1 Yard of Black 200 Denier
3' Hook and Loop Velcro
3' Shock Cord
Spool of Black Polyurethane Thread
Thanks for checking it out!!
Here are the pictures...
This is why I did the covers.
Taking the top, bottom and height measurements.
Marking the material with the measurements. I angled the bottom to fit the bottom of the coilover tighter. I also added 2" to each dimension so I can fold over and sew all the ends.
Sewing all four corners over.
Once all four sizes were folded and sewn, then I measured where the Velcro should go.
Added the Velcro to the closing seams.
The shock cord was slipped into the top and bottom edges to create an elastic seal and to hold the cover tight on the top and bottom.
Shock cord holding the bottom down.
Nice, tight and now protected.
Jive Turkey is offline   Reply With Quote
The Following User Says Thank You to Jive Turkey For This Useful Post:
TONYpepperon1 (04-24-2014)
Old 04-24-2014, 06:59 PM   #14
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Eibach sells similar stuff for offroad applications....
Beatrush Mounts ,BC BR, Bilstein, ISC N1, ST Coils, KW Coils and Stance Coilovers b2autodesigns Brakes, Suspension, Chassis 818 09-10-2017 08:33 AM
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 12:09 PM
WTB: Ksport Control Pro Coilovers or BC Racing Extreme Low Coilovers ProjectBrz Brakes, Suspension, Chassis 1 04-15-2014 12:21 AM
* BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * Speed Element Brakes, Suspension, Chassis 21 03-03-2014 08:56 PM
FS: (IL) KW Variant 3 coilovers and Stance Super Sport Coilovers ill roller Brakes, Suspension, Chassis 5 12-14-2013 03:02 PM
