Old 04-21-2014, 08:00 PM   #1
LEMON
Drives: 86
Smile Defi meter installation problem
Hi all, I am a new member.
I am trying to DIY to install the Defi Advance ZD on my 86
I have some problems about it.
First, instruction said a cable ( SPD & TACHO ) should be connected to the ECU to get the speed signal and the tacho signal.
Would I know the ECU location and the related pinout?
Thank you all.
LEMON is offline   Reply With Quote
Old 04-22-2014, 06:53 PM   #2
liquidsky44
liquidsky44's Avatar
Drives: AVO Turbo Subaru BRZ / Subaru WRX
I'm having the same problems as well. Without any wiring diagram or instructions. I could not get it to work at all. I have the Advance ZD Clubsport package and could only get the oil pressure, oil temp, and water temp to work.
AVO Turbo|Essex AP Sprint Kit|AVO Overpipe|HKS Hi-Power Spec L Catback|Cusco Engine Mounts|Whiteline Bushings|KW Clubsport|Defi Advance ZD|AEM Wideband Failsafe Gauge|Greddy ProFec Boost Controller|Tomei 2Way LSD|AEM Water/Meth Kit|PBM Angle Kit + Kunckles|Flatwell LCA|HKS Oil Cooler|Greddy High Cap. Diff Cooler|Sard ATF Oil Cooler|CSF Radiator|
liquidsky44 is offline   Reply With Quote
Old 04-22-2014, 07:00 PM   #3
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
If you have a brz you can search the aem failsafe threads and find the wire. If you have an frs you have to tap into a coil wire as the tach is canbus only.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
The Following User Says Thank You to Reaper For This Useful Post:
liquidsky44 (04-22-2014)
Old 04-23-2014, 06:27 AM   #4
LEMON
Drives: 86
Ooooooooo
It is a bad news
But I can't understand why Defi show there product works on 86
Old 04-25-2014, 10:56 AM   #5
liquidsky44
Finally got the rpm to work by tapping into the Tach signal on the A35-15 pin. But still unable to locate the speed signal.
Old 04-25-2014, 11:04 AM   #6
Reaper
Reaper's Avatar
Drives: violent
Could u post a picture of the wire
Old 04-27-2014, 06:17 PM   #7
liquidsky44
Actually the picture of the wire was posted up on the AEM Failsafe gauge wiring DIY. The easy way to locate the wire on the pin itself is by trying to locate the thinnest white/grayish color wire. That is where I tapped into for the Tach signal.
Old 04-28-2014, 07:45 PM   #8
LEMON
Drives: 86
I tapped the tacho signal on the ECU plug which is Defi recommendation
I sent a email to the defi jp and ask for technical support
A wiring diagram was attached in the reply mail
Old 04-28-2014, 07:46 PM   #9
LEMON
Drives: 86
But I couldn't found the speed signal yet
Old 06-25-2016, 05:00 PM   #10
nichiolas
Drives: GT86
Hey guys, do u know where should I place the three sensors?
nichiolas is offline   Reply With Quote
LHD 3-meter gauge-pod? TuxedoCartman Cosmetic Modification (Interior/Exterior/Lighting) 27 02-11-2015 06:19 PM
AFR Problem (maybe Fuel Pump installation bad) whitefrs Engine, Exhaust, Transmission 37 08-30-2013 02:36 PM
TRD Sports Meter Kit imravenit Electronics | Audio | NAV | Infotainment 18 05-10-2013 10:06 AM
G-force meter mikepaul21 Cosmetic Modification (Interior/Exterior/Lighting) 2 03-17-2013 02:24 PM
Does it have MPG meter? 8987846 BRZ First-Gen (2012+) — General Topics 34 05-18-2012 01:35 AM
