Old 04-21-2014, 12:27 AM   #1
becauseracecar1
becauseracecar1's Avatar
Drives:
Brake pad and fluid install cost
What is a reasonable amount that a shop should charge to install my track brake pads and brake fluid? Some places here(south florida) are charging $150!!
Thanks!!
2014 Ultramarine Scion FR-S
facebook.com/86motorsports
becauseracecar1 is offline   Reply With Quote
Old 04-21-2014, 12:30 AM   #2
retrosmiths
Drives: Scion FR-S Whiteout
Shouldn't take more than 2 hrs of labor max.
Sent from my phone. Might have typos. Sorry.
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 04-21-2014, 12:30 AM   #3
mashal
DADA
mashal's Avatar
Drives: 2013
Is like 200-300 around here
mashal is offline   Reply With Quote
Old 04-21-2014, 12:42 AM   #4
humfrz
Thanks!!
That sounds reasonable to me.
humfrz
Old 04-21-2014, 12:49 AM   #5
becauseracecar1
Drives:
I guess I better start learning how to do that stuff myself
Old 04-21-2014, 10:12 PM   #6
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Yeah $150 is pretty cheap. Figure $95/hr for about 2 hours + Material.
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
The Following User Says Thank You to AZP Installs For This Useful Post:
CSG Mike (04-21-2014)
Old 04-21-2014, 10:15 PM   #7
jvincent
jvincent's Avatar
I asked the same question of myself about a month ago.
I now have all the tools to do it myself and am just waiting for my track pads/fluid to arrive before doing the swap.
The Following User Says Thank You to jvincent For This Useful Post:
becauseracecar1 (04-21-2014)
Old 04-21-2014, 11:50 PM   #8
DR 86
DR 86's Avatar
Simple to do it yourself. Just do a gravity bleed of the fluid, don't even need a second person. And swapping pads is a cake walk, I do it when I arrive at the track and when I leave the track when I change from my street tires to track tires and back.
Perrin CAI|Perrin MCB|P&L header|Motiv OP/FP|MXP catback|Tein Type Flex coilovers|Eibach F/R sway bars|GS front strut brace|Street:PM HC+800/Track:Carbotech XP10|StopTech slotted rotors/SS lines|SBC RPF1s|Street:FK453/Winter:Pirelli SottoZero3/Track:Toyo R888s|Leg Sport rear spoiler|EcuTek Tuned|OEM oil cooler|4th/F1 brake lights
DR 86 is offline   Reply With Quote
The Following User Says Thank You to DR 86 For This Useful Post:
becauseracecar1 (04-22-2014)
Old 04-22-2014, 12:21 AM   #9
becauseracecar1
Drives:
I know this is a dumb question but do I need to change the fluid all the time too or just the pads?
Old 04-22-2014, 12:42 AM   #10
DR 86
DR 86's Avatar
No need to change the fluid all the time. If you're on stock tires, you probably won't be generating enough grip and carrying enough speed into braking zones to over heat the stock brake fluid for lapping days, but I'd change the fluid to something that can withstand more heat just to be safe. After that, just change the fluid at regular maintenance intervals (sooner if you are tracking a lot) or if you ever boil the fluid. I wouldn't use track pads on the street, as you won't be able to generate enough heat on the rotors with daily driving to maintain the transfer layer of brake pad compound, and very soon after your track day you will be enjoying a symphony of squealing pigs.
Old 04-22-2014, 01:25 AM   #11
becauseracecar1
Drives:
Ok Great!! So it would be ok for
me to just put track pads on with stock fluid for my first track day? My car is brand new, I'll be lucky if I have 1000 miles on it by Saturday(track day)
Old 04-22-2014, 08:46 AM   #12
AZP Installs
By "track pads" what do you mean?
Also if you only have 1k miles no need to flush the brake fluid.
As was stated if you have the OEM Prius tires you won't be taxing the brakes with them. I barely taxed my brakes with STi OEM Summers and 10+ years of track experience...
-mike
Old 04-22-2014, 09:19 AM   #13
FR-S Matt
I put on some Hawk's ceramic pads and they squeak like hell.... shims or no shims. I greased them just like instructed and bedded them in. Still squeak. I'll be replacing these soon and my fluid/lines while I'm at it. Just not sure if I should try it myself or have a shop do it. Figure it's easier since I'm doing a fluid swap, but the whole bleeding process kinda leaves me wondering.
Old 04-22-2014, 11:25 AM   #14
becauseracecar1
Drives:
-mike
I have the hawk hp +
Brake pad and fluid install shop recommendation(south florida)? becauseracecar1 Southeast 3 04-21-2014 11:32 AM
Supercharger install cost? LtS720 Forced Induction 22 10-12-2013 01:16 PM
Volunteers to help install my high temp brake fluid and pads with me? stockysnail Northwest 9 07-22-2013 06:15 PM
Cooked my brake fluid!!! markitect Tracking / Autocross / HPDE / Drifting 18 07-11-2013 11:53 AM
Coilover install cost? BRZranger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 08-14-2012 11:16 AM
