Old 04-13-2014, 06:42 PM   #1
PantsDants
Drives: Scion FR-S A/T, Whiteout
IAM dropping during freeway cruise
Hey guys, I've been seeing my IAM bounce around to as low as ~0.7 while just cruising in 6th on the freeway. It seems to correct itself and comes back up to 1.0 eventually in the city. I'm running an OFT, stage 2 with OFH on 92 octane from Shell. Other mods include drop-in dry filter, modified snorkel, and Perrin intake tube.
Here's my most recent log: http://datazap.me/u/pantsdants/41320...data=1-4-10-11
From what I've gathered so far, it looks like I get knock events related to increases in engine load at cruise RPM. I'm not sure if this qualifies as tip-in knock or not. The middle portion of the log represents relatively steady state freeway travel and shows the knock events I'm talking about. The end has some heavy throttle use and no knock events.
Any suggestions on what's causing the knock or how to correct this are appreciated!
PantsDants is offline   Reply With Quote
Old 04-13-2014, 06:45 PM   #2
jamesm
This is very common. If you'd like specific advice on resolving the issue feel free to pm me.
Old 04-13-2014, 07:43 PM   #3
steve99
Looks very similar to what we get here.
http://www.ft86club.com/forums/showthread.php?t=61820
I think it will get down to pulling some timing or running higher octane fuel
The higher rpm looks ok but you IAM is always less than 1 so once you get that sorted you will be running more advance up top and it may uncover a problem there.
@jamesm is a very helpful guy with experience I'm sure he can sort it out
K&N Air Filter installed, MPG dropping? HATED1 Engine, Exhaust, Transmission 35 05-09-2018 10:13 PM
Why does my Advance Multiplier keep dropping? jeebus Software Tuning 103 10-17-2016 05:29 PM
What's causing slow dropping revs? hchi rku Engine, Exhaust, Transmission 15 03-08-2014 06:39 AM
Grev dropping suddenly at high rpm brn12345 Software Tuning 17 01-01-2014 04:14 PM
Santa keeps dropping the BRZS off HeubergerMotors BRZ First-Gen (2012+) — General Topics 11 12-19-2013 06:26 PM
