Old 09-01-2013, 10:52 PM   #1
HATED1
HATED1's Avatar
Drives: 86
K&N Air Filter installed, MPG dropping?
As the title says, just put in a K&N Drop in filter and my MPGs are steadily dropping. Will it change after a few hundred miles? (ecu learning?) Something i forgot to do? thanks for any info.
HATED1 is offline   Reply With Quote
Old 09-01-2013, 10:54 PM   #2
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Did you clog the sound creator tube while you were at it?
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 09-01-2013, 11:09 PM   #3
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
I ended up resetting my ECU after installing the filter by disconnecting the negative battery terminal for 10 minutes. Not technically necessary for something so minor, but my mpg after a full relearn was more favorable. Worth a try.
Nightbringer is offline   Reply With Quote
Old 09-01-2013, 11:52 PM   #4
cfusionpm
Drives: Firestorm 6MT Scion FR-S
You sure its not just driving habits? My MPG has only gone up or stayed steady for the past several months. Mostly just consciously trying to drive economically and only pushing when I feel sporty. I've been averaging 25.4 mpg with about 80% city driving. My longer freeway trips see 33-35 mpg. I have a manual trans and put in a K&N drop in filter back in may.
2013 Firestorm 6MT Scion FR-S
cfusionpm is offline   Reply With Quote
Old 09-02-2013, 12:00 AM   #5
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
Ive been averaging 9.8
Young_makaveli is offline   Reply With Quote
Old 09-02-2013, 08:46 AM   #6
Mobius357
Drives: '15 WRX '13 Legacy '07 Colorado
@Young_makaveli MPG or L/100km?
Mobius357 is offline   Reply With Quote
Old 09-02-2013, 06:14 PM   #7
Trigonx
Drives: WRB BRZ
I installed the K&N air filter last weekend, have gone through one full tank of gas. My MPG has increased by 1.3 mpg, from 25.57 mpg to 26.9 mpg. I did not reset the ECU, I just popped it in.
Trigonx is offline   Reply With Quote
Old 09-02-2013, 06:15 PM   #8
Young_makaveli
Drives: 2013 frs
Sorry L/100km
Old 09-02-2013, 09:57 PM   #9
Young_makaveli
Drives: 2013 frs
Actually I'm getting
Old 09-02-2013, 10:10 PM   #10
cfusionpm
I wouldn't rely on the dash display, it's very.... optimistic. I track everything myself through the Android app FuelLog:
Old 09-02-2013, 10:29 PM   #11
xjohnx
Grip>Slip
xjohnx's Avatar
clean your maf sensor.
Old 09-03-2013, 09:35 AM   #12
clintavo
What he said. Get a bottle of MAF spray cleaner.
I cleaned mine 50 miles after a K&N install just to be safe. Probably will do it again before I get a tune.
clintavo is offline   Reply With Quote
Old 09-03-2013, 09:39 AM   #13
FR-S Matt
Fuelly is a great tool to use as well just like that app. Runs off your odometer or trip meter. My MPG gauge is usually 1.5-2 mpg off from the actual number mainly because it factors in idle time.
Old 09-04-2013, 05:54 AM   #14
projectXTR
Drives: Sterling Silver BRZ
Attachment 50110
8.5 here , driving spirited every now and then, not even that much highway... I wonder how much it would drop if I were to put in an aftermarket drop in filter
projectXTR is offline   Reply With Quote
Tint, lights and backup cam installed, and camber kit installed in Gainesville area? husker741 Southeast 2 08-16-2013 03:59 PM
Dropping car off Friday for TSB service.. some questions pgeist Issues | Warranty | Recalls / TSB 6 07-15-2013 02:45 PM
Renick Subaru installed the wrong filter! blkwrxwag Southern California 13 06-05-2013 01:44 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
GT86 Jaw dropping wallpaper picture... Smooxie FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 20 12-12-2011 10:46 AM
