Old 04-11-2014, 06:02 PM   #1
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Exclamation Need to get a Catback doughnut flange (Just the flange), but where???
Story is I have the TRD exhaust on my BRZ, but I want a 2.5" midpipe not the crummy under 2" midpipe thats on the stock TRD exhaust... So I went to the exhaust shop, and they don't want to modify the TINY TRD flange as seen here:
(stock is on the left, TRD on the right)
And I'm keeping my stock midpipe (not the TRD midpipe, the stock stock midpipe) so I don't want to cut the flange off that pipe.
Does ANYONE know where to get these flanges at for our cars??? I mean just the one part like this:
All the companies making aftermarket catbacks have to be getting these from somewhere for their exhausts, so SOMEONE must carry this in the correct size... (the one pictured is going from a 2.5" to a 2.25". I want 2.25" to 2.25" or maybe 2.25" to 2.5" if thats an option)
Kostamojen is offline   Reply With Quote
Old 04-11-2014, 10:05 PM   #2
DoctorNick
DoctorNick's Avatar
Drives: '13 BRZ
http://tinyurl.com/haveyoulookedatjegsKostamojen
DoctorNick is offline   Reply With Quote
Old 04-11-2014, 11:22 PM   #3
Kostamojen
Not finding anything on summit.
Old 04-11-2014, 11:40 PM   #4
Zaneman
Drives: 2013 BRZ limited
I ran into this with another car about 7 years ago. I remember being able to find it on one website for roughly $45....so um yeah shot in the dark. Good luck.
It was for an Integra or RSX... Some honda site.
Zaneman is offline   Reply With Quote
Old 04-11-2014, 11:42 PM   #5
xwd
http://www.ebay.com/itm/BLOX-Racing-...e54390&vxp=mtr
http://bloxracing.com/shop/index.php...ry&path=64_112
Old 04-12-2014, 01:38 AM   #6
Kostamojen
Are we sure those bolt holes will match up?
Old 04-12-2014, 01:54 AM   #7
Kostamojen
Screw it, I'll just order one and find out.
Old 04-12-2014, 07:20 AM   #8
roddy
roddy's Avatar
Drives: '13 Ultramarine
The exhaust shop I went to for a custom mid pipe for my TRD had a flange in stock. The tech said it was for a Toyota truck. That's all the info I have. I suspect it is either from a V6 Tacoma or a RAV 4. Hope that helps narrow down your search. Once you get this done, you'll instantly notice an increase in pull from 5500 on up (even more so if you're running an aftermarket over pipe/front pipe).
Edit: @Kostamojen Have you decided what to use for a resonator?
Old 04-12-2014, 08:44 AM   #9
wparsons
wparsons's Avatar
SOOO glad I didn't get the TRD exhaust after seeing this... why did they put a smaller midpipe on than stock?
flickr
Old 04-12-2014, 02:17 PM   #10
Kostamojen
Vibrant Super Quiet resonator. Seems like its got the best reviews out there.
No idea. Glad I got mine used for cheap so it doesn't bother me about fixing this.
Old 04-12-2014, 02:32 PM   #11
DAEMANO
Time Traveller
Someone posted a long while ago a few dynos that suggests the increased back pressure from the TRD midpipe, on the NA engine, increased midrange torque in the dip (where the stock car) needs it most. If going FI or hunting max HP (not under the curve) improvments swapping out for a new mid-pipe could be just the thing.
Old 04-12-2014, 09:10 PM   #12
Kostamojen
Having been an NA Subaru guy for over ten years...
...the only way to fix the torque dip is to not try and fix it at all.
Header Flange Specs? boredom.is.me Engine, Exhaust, Transmission 18 11-11-2013 04:28 PM
Front hub/knuckle/flange shared with any other model? ft_sjo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 05-19-2013 03:03 AM
Borla UEL flange, more in common with a pretzel then a flange. Adeets Engine, Exhaust, Transmission 13 04-12-2013 05:38 PM
Stock exhaust flange RWD-boxer Engine, Exhaust, Transmission 4 03-05-2013 08:27 PM
Header flange Silverdub Engine, Exhaust, Transmission 0 08-09-2012 07:43 PM
