Drives: Turbo BRZ, Celica Supra
Breaking up at 4k rpm turbo Brz.
Car developed a problem with breaking up and backfiring at 4k under boost. Ideas? 9psi, 550cc injectors, in tank 255, logs show the afr unstable and towards the lean end at about 15.1. Not going into boost until resolved. Issue started with occasional pop, now will not rev past 4k under boost. Threw a multiple cylinder random misfire code.
Motorsports
Drives: 19BRZ PP, 16 M4
What are the MAF voltages doing?
Douglas W.
in orbe terrum non visi
Drives: violent
e85?
DI seals?
The Frozen North
#5 | |
I Love custom Turbo kits
Drives: Limited BRZ
Quick test. With car idle, if you blip the throttle, do you get firecracking pops? If yes, hints at DI seals, if not, hints at you are going really lean because of improper pump install. I'm inclined to bad pump or wrong install letting fuel pressure leak out of O rings.
#6 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
Boosted Member
Is the car only leaning out and misfire as you come into boost? Can you lightly drive up to the 4k+ rpm range without issue?
Reason I ask is because my car has similar issue when it's colder outside at around the same rpm, no matter the engine load or boost. Been chasing the issue for a while now and it's looking more and more like the MAP sensor. Changing nothing except the MAP scaling and switching back to stock MAP sensor fixed it for me but I can't actually run the stock one due to it only reading like 5psi. I know some of the innovate guys are/were also having similar issues.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG 2011 Honda CBR1000RR 2010 Subaru Impreza WRX PRM SSM |
Check your spark plugs, and also for vacuum/boost leak.
Boosted Member
Didn't somebody have an issue with the coil packs failing and causing these types of issues?
#10 |
Drives: violent
I think that was csg? I dont remember his full name
Sent from my SAMSUNG-SGH-I747 using Tapatalk
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#12 |
Log with equivilance ratio requested afr. And fuel system status. Sounds like you are running in closed loop with bad injector scaling and maxing out fuel trims.
Post any logs you have for is to review and I sure we can figure it out.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
#13 | |
Misfire code is telling me check the plugs/coilpack and you will probably find your issue. If that doesn't turn up anything check to make sure your wiring didn't get burned resting on something hot maybe? Or the wires accidentally ripped out of a connecter. |
#14 | |
| I keep breaking lug studs!!! | Guff | Issues | Warranty | Recalls / TSB | 59 | 12-30-2015 12:34 AM |
| Breaking-Bad SWP Build | mwjcyber | Member's Car Journals | 7 | 02-17-2014 08:12 PM |
| Down hill breaking... ABS? | shaofis | Issues | Warranty | Recalls / TSB | 11 | 10-22-2012 04:28 PM |
| Breaking Bad: Season 5 | |-Goku-| | Off-Topic Lounge [WARNING: NO POLITICS] | 15 | 07-22-2012 01:02 AM |
