Old 04-07-2014, 10:39 AM   #1
transition
Rubbing after an alignment w/ RCE Yellows?
So i got an alignment last week and i'm now for the first time noticing that a sudden hard turn left is generating what sounds like rubbing when driving on the stock wheels/tires. I never heard the sound previously when on my other wheels (17x8 235/40/17 +35). I was just prepping for a long road trip so that's why i'm back on the stock wheels. Suspension changes are only RCE Yellows on stock struts and Whiteline camber bolts up front. I'm not hearing the noise anywhere except what seems to be the driver front wheel. A sudden hard turn right isn't generating the same noise.
transition is offline   Reply With Quote
Old 04-07-2014, 01:34 PM   #2
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
Rear camber look wonky. Doesn't make much sense as to why they would have such a big difference from left to right. If car is rolling hard and you have that much negative camber on the right, that might be the source of the sound.
enjoyminutemaid is offline   Reply With Quote
Old 04-07-2014, 02:18 PM   #3
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
your SAI is 1 degree different left to right, this is odd, and your caster is off by a little left to right as well
something was not aligned properly.
Old 04-07-2014, 02:23 PM   #4
transition
Huh, so apparently the alignment guy did more harm then good. Still can't find the source of the rubbing sound. Took off all 4 wheels to inspect and no obvious wear points.
Old 04-07-2014, 02:25 PM   #5
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
is this your first ever alignment on the FRS or have you done some before? Same shop? Do you have previous print outs?
Old 04-07-2014, 02:27 PM   #6
transition
First alignment. The alignment was done by a one man shop that only does alignments for around 10 years. He had a hunter alignment machine although i guess that doesn't do you any good if you don't know what you're doing.
Old 04-07-2014, 02:34 PM   #7
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
The cars are like this off the factory floor.
Im at -1.8 LR, -2.8 RR
supramkivtt2jz is offline   Reply With Quote
Old 04-07-2014, 02:39 PM   #8
transition
How about the SAI? Is that within spec?
Old 04-07-2014, 03:02 PM   #9
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
I dont have a print out so i couldnt even begin to guess.
Old 04-07-2014, 03:14 PM   #10
brz7400
brz7400's Avatar
Drives: Subaru BRZ
maybe your right side camber bolt was not tightened enough?
i have oem crash bolt and the torque spec on them were pretty high like 130 ft lb or something, i remember working the torque wrench wondering when it would click.
not sure of torque spec on whiteline, but i assume it should be high to keep it in place as well.
brz7400 is offline   Reply With Quote
Old 04-07-2014, 03:27 PM   #11
transition
I'm going to throw the other wheels/tires on the car to see if the sound still exists. Otherwise i'm getting another alignment this friday.
Old 04-07-2014, 04:01 PM   #12
darthwong1138
Drives: Raven FR-S
Every lowered FRS/BRZ i have seen has this problem. Its always the right side that has more camber too.
darthwong1138 is offline   Reply With Quote
Old 04-07-2014, 04:03 PM   #13
TrqlessWonder
Drives: 2014 FR-S
That alignment doesn't actually look too bad. The rear camber looks weird, but he doesn't have much he can do with that, unless you bought parts specifically for him to install to correct the rear camber. Otherwise, you can only adjust toe back there.
While typing out a much longer reply, I did remember something, and am starting to think it might be something for you to look into. My first ever autocross with this particular car was a couple weeks ago, in the rain. So, one run, I brain farted and didn't turn off the traction and stability control. Result? Well, I didn't spin, and I was slower, and at just about every turn that required any bravery to speak of, lots of DSC/TC intervention. Noisy, grinding/rubbing/scrubbing noises as the brakes ruined my run. The bonus? It being a counter-clockwise course, the intervention was much more severe when turning left. My alignment isn't that far off from yours, but my car isn't lowered.
Outside of that, put the factory wheels back on, jack up that corner and turn the wheel to full lock and see what it *might* contact if it were to. Car being lowered, and the stock wheels/offset could combine to put the wheel/tire enough farther inboard to contact something. Then look for a shiny spot if it's metal, and scuffs/scrapes if it's plastic.
In any event, save your money on the alignment for right now, particularly if it drives straight. You'll be extra irritated if you go and spend money on a good alignment (his place, or anywhere else), and it doesnt fix it. Solutions are much more effective when they are used on the problems they are intended for. No amount of alignment change is going to make the stability control stop interfering, you have to press the button for that. If you want the rear camber corrected, get a set of offset bushings or new LCAs.
tl;dr - Find that spot where you find yourself needing to yank hard left, and go there. Make the noises happen. Then - Turn off the TC/DSC, repeat test. I think it's the nannies interfering, not the alignment. More likely that the springs were installed incorrectly at this point.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 04-07-2014, 04:20 PM   #14
transition
Thanks for the reply.
I always drive with all assists off so this shouldn't be the issue. I haven't tried the pedal dance yet.
I've taken off all four wheels multiple times now - haven't found anything yet. And i am on stock wheels / tires right now. I'm going to go back to my aftermarket wheels to see if i hear the rubbing noise as i never heard the sound before i went back to stock wheels. I just used some crayons to mark the inside of my front tires to see if it is actually rub that i've missed.
Will update again after switching to other wheel setup.
How much rubbing is too much rubbing? Pokeguyjai Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 12-10-2013 08:04 PM
FS: RCE Yellows + Koni Yellows ***SOLD*** raul Brakes, Suspension, Chassis 0 10-22-2013 01:14 PM
Feeler: RCE Yellows + Koni Yellows *PRE-ASSEMBLED* raul Brakes, Suspension, Chassis 0 08-09-2013 03:22 PM
RCE Yellows + Koni Yellows + Whiteline Camber Adjustment Bushings raul Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 05-24-2013 08:33 AM
Rubbing sound? Mo707 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-15-2013 11:06 AM
