Old 12-09-2013, 10:38 PM   #1
Pokeguyjai
Pokeguyjai's Avatar
Drives: 2013 GBS BRZ (AT)
How much rubbing is too much rubbing?
Hi Guys,
I am running RCE Yellows on stock dampers (planning to replace them with Koni Yellows soon). I have 18x9.5 +35 TC105ns with 245/35 Michelin PSS.
I am getting a little rubbing when I pull out of my driveway and I turn the wheel all the way to the right. It feels like my my car is shuttering a little bit (not exactly an accurate description but can't think of the right word)
I took my wheels off a few weeks ago and I noticed that there was a black mark on my RCE Yellows, which I am guessing is the tire rubbing against the suspension. Some parts were worn through where I could see the metal of the suspension, only a small bit though.
I suppose an easy remedy would be to not turn the wheel fully when I get out of my driveway. But I was just wondering if a little bit of rubbing is bad?
Thanks in advance gents
Pokeguyjai is offline   Reply With Quote
Old 12-09-2013, 10:40 PM   #2
diss7
Drives: AE86, 2x GT86, TE27
I expected more filth
diss7 is offline   Reply With Quote
Old 12-09-2013, 10:52 PM   #3
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Throw on some 5mm spacers on fronts for sure, only thing is already a very aggressive offset. So if you don't want much more poke, don't want rub you need to either
A.) get different wheels / offset
B.) coilovers
That'/ your choices or wait till something wears through at worst time I suppose.
Old 12-09-2013, 11:07 PM   #4
Pokeguyjai
Pokeguyjai's Avatar
It's to lure you in so you would read my boring yet neurotic question.
B.) coilovers
Or I could not turn the wheel all the way! LOL
I plan on keeping an eye on it, but I am guessing it is only rubbing when I feel that "shuddering"? Thanks
Old 12-10-2013, 03:01 AM   #5
rallysrt
Drives: shitboxes
Worry a lot more about your tires than your springs when you're checking things out. No more than some scuffs on the sidewalls are fine but if there's any gouging, try even 3mm spacers and possibly new tires if it's bad.
rallysrt is offline   Reply With Quote
Old 12-10-2013, 03:25 AM   #6
Wolfking
Wolfking's Avatar
Drives: Asphalt FRS
Don't be silly! Did you really ask if improper clearance is bad?
Wolfking is offline   Reply With Quote
Old 12-10-2013, 03:29 AM   #7
asia_minor
Superleggera
Drives: 2016 Mazda MX-5
"That's what you mother said last night!"
Personally I wouldn't take any rubbing at all.
asia_minor is offline   Reply With Quote
Old 12-10-2013, 02:52 PM   #8
Pokeguyjai
Pokeguyjai's Avatar
Yeh I looked at the tires and there were no gouges. The tires looked perfectly fine, I'll check again tonight when I get a chance.
Old 12-10-2013, 03:14 PM   #9
Darkrune
Darkrune's Avatar
Drives: 2017 86
Sounds to me like your wheels and tires are too aggressive for the front. I would do 18 8.5 and 235 40 tires. That probably would fix it.
P.S. that offset etc for the rear is good though.
Darkrune is offline   Reply With Quote
Old 12-10-2013, 03:17 PM   #10
Pokeguyjai
Pokeguyjai's Avatar
Funny thing is that people have the same wheel setups, higher offsets than I do, stock suspension, and they are not getting any rubbing.
Old 12-10-2013, 03:24 PM   #11
mfbmike
Drives: 2013 FRS, 2008 R32
Camber.
mfbmike is offline   Reply With Quote
Old 12-10-2013, 04:14 PM   #12
Darkrune
Darkrune's Avatar
Drives: 2017 86
Like mike says, alignment has a lot to do with rubbing. Also, 245 is pretty wide for tires up front. I think I have seen 240 45 be a bit of a benchmark for the front. But tires run different sizes too, it is a crap shoot if you aren't an expert, which I am not, but I have experience with stuff like this.
Old 12-10-2013, 04:22 PM   #13
Pokeguyjai
Pokeguyjai's Avatar
Originally Posted by mfbmike View Post
Camber.
I have -2 degrees in the front. Thanks guys for the help.
Old 12-10-2013, 04:25 PM   #14
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
any rubbing is too much rubbing. That shit gets annoying when cornering.
bkblitzed is offline   Reply With Quote
Rubbing issues boricua FR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 11-23-2013 07:28 PM
window sounds like its rubbing jybrd Issues | Warranty | Recalls / TSB 9 07-10-2013 05:45 PM
Rubbing sound? Mo707 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-15-2013 11:06 AM
Tire rubbing sound, Please Help dco107 Scion FR-S / Toyota 86 GT86 General Forum 6 01-11-2013 10:05 AM
License plate rubbing on Trunk Jayde BRZ First-Gen (2012+) — General Topics 28 08-11-2012 09:45 AM
