Drives: 2014 Monogram FR-S White MT
Coasting to a stop in higher gear
So I'm still in break-in period, so my question is in that context.
When I slow down to a stop, I keep the car in whatever gear I was running in and use brakes to stop and then when revs get to about 1500 and I'm down to about 10mph or so, I step on clutch and stop. Is this lugging the engine? I'm using no throttle during the coast, and if I need to accelerate again for whatever reason, I always shift to the right gear before giving throttle. |
Dirt Trackin'
Drives: '13 Raven FR-S MT
Sounds fine to me. I wouldn't worry about it. If you're not on the throttle and the engine is above idle, it shouldn't be firing the cylinders anyway.
#3 | |
Drives: 2013 GBS BRZ Limited
If you take it out of gear and coast, the ECU will provide fuel to keep the engine from dieing. |
Dirt Trackin'
right... if you take it out of gear the engine will drop down to idle, then it will start firing to keep it running at idle. Until it drops down to idle, I would imagine that it's not firing (though I can't say that with 100% certainty).
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Drive like us stole it, that's my break in
SOLD THEM BOTH
Hers: 2007 987S Mine: 2012 991S That was fun, thanks Hachi ![]() |
No, as long as the gear isn't pulling the engine RPM below idle, you're fine.
I would personally recommend learning how to rev match and downshift properly, but only if you're interested (btw it's fun). This is not just for performance driving, but could help if you need to scoot out of the way of danger, being in a gear/rpm that can actually move you quickly (instead of 6th gear at 1000 rpm, where you'd just lug the engine to death and not accelerate). |
Drives: Yes
lugging only happens when you try to apply throttle at low RPMs. Coasting until right before idling/stalling RPM's is fine, if not recommended
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
| higher Boost? | Scalzo | Forced Induction | 19 | 09-10-2014 05:20 PM |
| At stop lights, do you stay in gear or go into neutral? | boredom.is.me | Scion FR-S / Toyota 86 GT86 General Forum | 77 | 07-25-2014 09:23 PM |
| Where can i get fuel higher than 91? | XPR Small Block | Northern California | 22 | 03-24-2013 09:56 AM |
| Coasting? | Ben_G | Engine, Exhaust, Transmission | 22 | 03-22-2013 02:36 AM |
| Coasting into the gas station? | bdanisi | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 03-07-2013 08:16 PM |
