Old 10-25-2013, 12:30 PM   #1
Blizzard
Drives: '13 FR-S Whiteout
Noise after KW V3 install?
Just finished the install of my KW V3's and go for a quick drive. There is an awful noise coming from the rear coilovers during any suspension travel. I go back to the garage and take it apart and check everything out, raise it up a bit just in case, and put it all back, double checking it all. Guess what?! Damn noise is still there. Sounds like it is maybe coming from the top hats, not sure though. Both sides are loud. I am stumped.
Blizzard is offline   Reply With Quote
Old 10-25-2013, 12:46 PM   #2
cnk
Drives: '13 DGM BRZ Limited
What top hats are you using? Did you load the suspension before torquing everything down? How low are you?
I'm lowered 1" and no noises. It could be your sway bar endlinks as some have reported noises when lowered quite a bit.
cnk is offline   Reply With Quote
Old 10-25-2013, 02:15 PM   #3
brn12345
brn12345's Avatar
Have the KW Clubsports and I too have a loud clanking sound from the rear when I hit bumps. I am still on stock sway bar end links and will be changing those to adjustable ones over the next 2 days. I will report back if the sound goes away.
brn12345 is offline   Reply With Quote
Old 10-25-2013, 05:51 PM   #4
Blizzard
I am using OEM top hats. Yes, suspension was torqued properly. I actually raised the car up to see if that was the problem, I am not sure how much lower it is, but I am not "slammed" at all. I hope it is the sway bar endlinks and not something broken!
The Following User Says Thank You to Blizzard For This Useful Post:
xxGiXxeRxx (12-10-2015)
Old 10-25-2013, 06:17 PM   #5
Blizzard
Yeah, my noise is a sort of clanking as well. Hope what you do works!
Old 10-27-2013, 03:37 AM   #6
brn12345
brn12345's Avatar
Did the end links. Still sounds the same. Mechanic says it's the metal on metal top hats and there isn't much that can be done.
Old 10-28-2013, 02:05 PM   #7
Blizzard
Bummer. I fixed my problem, and it was as simple as tightening down that center nut more (so it was the same thing you are experiencing). I was very surprised that was the problem seeing as I torqued it down pretty good. I had a buddy hold the 8mm top in place and I cranked it down quite a few more turns and voila it is fixed. Might want to give it a try?
Old 10-28-2013, 02:21 PM   #8
cnk
Just be careful with those nuts on the rear. When I was speaking with Myles from RaceComp, he told me that he's seen more than a few snap when over-torqued.
Old 10-28-2013, 03:08 PM   #9
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
Your suspension shouldn't make any noise like that, your mechanic is a fool. I have had my V3's on for over 3000 miles now. This is the 3rd thread about clunking KW's in the past 2 days. All sounds like the same thing the top mount center nut came loose a bit after driving. Take the coilover off, use a hex to keep the strut from spinning and a wrench to tighten the center nut, reinstall coil, enjoy.
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
Road noise? Tread Noise? zERoTu Issues | Warranty | Recalls / TSB 21 10-07-2020 10:21 PM
Engine bay noise after HU install... ghost86 Electronics | Audio | NAV | Infotainment 13 06-06-2013 08:52 AM
Noise from front calipers after pad/rotor install BRZranger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 03-24-2013 12:48 PM
aFe Install, keep or loose noise generator jflogerzi Engine, Exhaust, Transmission 6 01-19-2013 06:50 PM
