Old 04-01-2014, 05:21 PM   #1
JW89225
Drives: E92
Winjet JDM Headlight LED + lowbeam
Is there anyway to make the LED bar to turn on with the lowbeam/highbeam ?
2013 Scion FR-S 6AT
JW89225 is offline   Reply With Quote
Old 04-02-2014, 05:40 PM   #2
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
yes there is. with this part right here
http://www.fteightysix.com/whats-new.../#.Uzx1wfldW0k
86SPEED is offline   Reply With Quote
Old 04-02-2014, 06:13 PM   #3
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
I believe this is what you are looking for however not sure if it works on winjets but deff works on the series 10 and jdm lights. I will be giving this a shot once I throw my winjets on too
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 04-02-2014, 06:20 PM   #4
86SPEED
86SPEED's Avatar
the issue your going to run into is the winjet has 4 wires, two for the headlight, two for the highbeam/drl. the part i know your talking about needs the power from the parking light wire. then it back feeds the system to the other side. what we make and sale here does not back feed and simply plugs into the plug and crimps in line of the drl wire.. its easy to do.
Old 04-02-2014, 11:44 PM   #5
brokedrifter
Drives: Scion FR-S white
Is this something that you have to cut factory wires to install or just worse within the winjet headlight?
brokedrifter is offline   Reply With Quote
Old 04-03-2014, 02:04 AM   #6
86SPEED
86SPEED's Avatar
We made it so you do not need to cut any factory wires - It taps and cust one wire on the winjet in side the housing
Old 04-03-2014, 08:00 PM   #7
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Good to know. I wasn't too sure if it would work on winjets consider the harness is different.
Out of the FRS game
The Following User Says Thank You to Mr.Jay For This Useful Post:
86SPEED (04-04-2014)
Winjet Headlight Owner Review JohnAyySays Cosmetic Modification (Interior/Exterior/Lighting) 10 10-13-2015 02:14 AM
WINJET Headlight Question HATED1 Cosmetic Modification (Interior/Exterior/Lighting) 5 10-12-2015 04:46 AM
HELP: WINJET Headlight LED strip INOP 1SIKFRS Cosmetic Modification (Interior/Exterior/Lighting) 10 09-02-2014 12:28 AM
Does anyone know how to turn off the Winjet Headlight led's? JakeNash Cosmetic Modification (Interior/Exterior/Lighting) 0 03-20-2014 07:21 PM
Winjet Headlight HIDs 6000K SPEEDGOD Canada Classifieds 1 03-19-2014 03:14 PM
