Old 03-31-2014, 08:51 PM   #1
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
Is your overpipe/front pipe making noise/leaking?
Wanted to see if I could compile some info for everyone. Did/does your exhaust setup rattle? And which header do you have? Or did you fix the noise issues, by tightening?
unsurety is offline   Reply With Quote
Old 03-31-2014, 09:00 PM   #2
roddy
roddy's Avatar
Drives: '13 Ultramarine
Stock manifold, Nameless over pipe/front pipe combo (with cat and resonator), and custom mid pipe...no leaks or rattles here.
Old 03-31-2014, 09:01 PM   #3
CARNZ
CHECK ENGINE
Drives: 2004 STi
Stock header (until my OFH comes in), Perrin Overpipe and Perrin 3 inch frontpipe, no rattles or leaks to report here
i don't cry about crickets
CARNZ is offline   Reply With Quote
Old 03-31-2014, 09:16 PM   #4
mrk1
Drives: Sterling BRZ Ltd
As a general statement most leak problem I have seen with aftermarket exhaust parts I have seen are either real crummy gaskets or people crushing the life out of the gasket.
I have a custom exhaust so I can't really contribute but I have no leaks or rattles and my systems uses good old 2 bolt flanges.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
TRD exhaust + front pipe and overpipe? FRSBRZGT86FAN Engine, Exhaust, Transmission 2 11-02-2020 08:48 AM
front pipe / overpipe replacement 350matt Engine, Exhaust, Transmission 1 03-25-2014 04:29 PM
WTB: NY/LI catless front pipe and overpipe whitefrs Want-To-Buy Requests 1 08-29-2013 08:36 PM
OVERPIPE+FRONT PIPE QUESTION MontrealFRS Engine, Exhaust, Transmission 10 04-27-2013 02:59 AM
Will a resonated front pipe make alot less noise than test pipe? Mike86 Engine, Exhaust, Transmission 8 01-26-2013 08:24 PM
