Drives: 2014 BRZ - 2004 GLI
Pics! TRD sway bars and TRD quickshifter.
I figured I would take some pictures of what is included in the kits. Made this post mainly for the sways as I couldn't find anything about them other than a blurry camera phone picture. Didn't want to set up the photo booth or spend a lot of time taking photos so full auto setting is what you get.
TRD doesn't list the front sway bar size and on the website reports a 17.5mm rear sway bar. The TRD documents for the sway bar list 21mm front and 16mm rear. Actual measurements, not pictured, are 20.96mm Front and 16.2mm rear. (I figured the epoxy coating varies a bit) As compared to the already discussed stock 18mm Front and 14mm rear. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() And some shots of the quick shifter ![]() ![]() ![]() ![]() ![]() ![]() If anyone wants any more or better shots of either, or if you want a PDF of the directions just let me know. I'll post a review when I get these installed. |
Long Distance Driver
I wonder what the size of TRD Japan's sway bars are (yellow bars)
Drives: Subaru BRZ Limited
PROUD OF BOXER
Drives: Raven FR-S
#6 | |
The unknown size was referencing the JDM yellow sway bars which I do not own. Stock sway bars: 18mmF / 14mmR TRD USDM (Reds): 21mmF / 16mmR (TRD USA website says the rear is supposed to be 17.5mm, the Install instructions list 16mm. However actual measurements were 20.96mmF / 16.2mmR) TRD JDM (Yellows): Unknown sizes |
I believe that should be front: 17 mm and Rear 15 mm. Thanks. http://86-club.tw/forum.php?mod=view...BE%B6%C9%B1%EC |
#8 | |
![]() I wonder if they're hollow or solid. I should translate that page. Thanks for the info. I installed the sways and the car feels heavier in a straight line and can get the tail out more controllably. However I quite dislike the short shifter as it feels like I need quite a bit more effort to shift into gear. (Personal preference.) |
#9 | |
I think that is solid, if I remember correctly. Thanks. |
#10 |
Drives: 2014 Raven FR-S monogram
Have both TRD sway bars and TRD quick shift on my 2014 Monogram.
#11 | |
Now it appears to be a Solid Front 17mm bar for yellow still unknown if its hollow or solid for the 15mm rear for yellow The red would have the most change while the yellow has a probably minute, but effective difference. Very interested in trying out both, but wouldn't the Red front bar induce more understeer? hmm
#12 | |
aeiou
Drives: WRB BRZ
#13 |
#14 |
That Guy
Drives: 2013 asphalt FRS MT
Can the quick shifter work with aftermarket short shifters? What's the throw ?reduction
| sway bars | shehan1212 | NY / NJ / CT / PA | 1 | 03-18-2014 10:17 PM |
| BRZ / F86 Sway bars | timlewis82 | Australia Classifieds | 0 | 02-02-2014 02:58 AM |
| brz and fr-s sway bars different? | 1010110 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 08-03-2013 01:43 AM |
| ST sway bars | bmxhotsauce | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 05-09-2013 03:11 PM |
| FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! | NJA | Brakes, Suspension, Chassis | 18 | 04-07-2013 06:00 PM |
