Old 03-28-2014, 04:20 PM   #1
Createddeleted
Drives: 2014 BRZ - 2004 GLI
Pics! TRD sway bars and TRD quickshifter.
I figured I would take some pictures of what is included in the kits. Made this post mainly for the sways as I couldn't find anything about them other than a blurry camera phone picture. Didn't want to set up the photo booth or spend a lot of time taking photos so full auto setting is what you get.
TRD doesn't list the front sway bar size and on the website reports a 17.5mm rear sway bar.
The TRD documents for the sway bar list 21mm front and 16mm rear. Actual measurements, not pictured, are 20.96mm Front and 16.2mm rear. (I figured the epoxy coating varies a bit)
As compared to the already discussed stock 18mm Front and 14mm rear.
And some shots of the quick shifter
If anyone wants any more or better shots of either, or if you want a PDF of the directions just let me know.
I'll post a review when I get these installed.
Createddeleted is offline   Reply With Quote
The Following 4 Users Say Thank You to Createddeleted For This Useful Post:
gonzo (07-07-2014), husker741 (03-28-2014), nosi9frs (06-21-2014), unsurety (03-29-2014)
Old 03-28-2014, 04:30 PM   #2
Sargy
Long Distance Driver
Sargy's Avatar
I wonder what the size of TRD Japan's sway bars are (yellow bars)
Sargy is offline   Reply With Quote
Old 03-28-2014, 04:47 PM   #3
Createddeleted
That I am unsure of. I have not found the sizes listed anywhere yet.
Old 03-28-2014, 11:11 PM   #4
cslntuee
Drives: Subaru BRZ Limited
Could you give a road test review after installing the TRD sway bar?
Thanks.
cslntuee is offline   Reply With Quote
Old 03-28-2014, 11:50 PM   #5
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Can you measure for us? Calipers are dirty cheap at harbor freight
supramkivtt2jz is offline   Reply With Quote
Old 03-29-2014, 12:31 AM   #6
Createddeleted
If you read above I posted the sizes for the USDM sway bars. (What trd's website says, what trd's instructions say they are, and the actual measurements I took with a caliper.)
The unknown size was referencing the JDM yellow sway bars which I do not own.
Stock sway bars: 18mmF / 14mmR
TRD USDM (Reds): 21mmF / 16mmR (TRD USA website says the rear is supposed to be 17.5mm, the Install instructions list 16mm. However actual measurements were 20.96mmF / 16.2mmR)
TRD JDM (Yellows): Unknown sizes
The Following User Says Thank You to Createddeleted For This Useful Post:
supramkivtt2jz (03-29-2014)
Old 03-29-2014, 07:59 PM   #7
cslntuee
I believe that should be front: 17 mm and Rear 15 mm.
Thanks.
http://86-club.tw/forum.php?mod=view...BE%B6%C9%B1%EC
Old 03-29-2014, 11:20 PM   #8
Createddeleted
Thanks.
I wonder if they're hollow or solid. I should translate that page. Thanks for the info.
I installed the sways and the car feels heavier in a straight line and can get the tail out more controllably. However I quite dislike the short shifter as it feels like I need quite a bit more effort to shift into gear. (Personal preference.)
The Following 2 Users Say Thank You to Createddeleted For This Useful Post:
cslntuee (03-30-2014), Sargy (03-30-2014)
Old 03-30-2014, 12:03 AM   #9
cslntuee
I think that is solid, if I remember correctly.
Thanks.
Old 03-30-2014, 01:13 AM   #10
Speeeddemon99
Drives: 2014 Raven FR-S monogram
Have both TRD sway bars and TRD quick shift on my 2014 Monogram.
Speeeddemon99 is offline   Reply With Quote
The Following User Says Thank You to Speeeddemon99 For This Useful Post:
WallsAndFoundations (07-08-2014)
Old 03-30-2014, 01:44 PM   #11
Sargy
Sargy's Avatar
Now it appears to be a Solid Front 17mm bar for yellow
still unknown if its hollow or solid for the 15mm rear for yellow
The red would have the most change while the yellow has a probably minute, but effective difference. Very interested in trying out both, but wouldn't the Red front bar induce more understeer? hmm
Old 03-31-2014, 05:35 AM   #12
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
The idea is that the thicker rear sway bar will induce more oversteer, thus mitigating the added understeer. Especially as the sways come in a kit, it seems.
unsurety is offline   Reply With Quote
The Following User Says Thank You to unsurety For This Useful Post:
Sargy (03-31-2014)
Old 06-22-2014, 12:54 AM   #13
cslntuee
Could you give a road test review related to TRD sway bar?
Thanks.
Old 06-22-2014, 08:50 AM   #14
Calum
That Guy
Drives: 2013 asphalt FRS MT
Can the quick shifter work with aftermarket short shifters? What's the throw ?reduction
sway bars shehan1212 NY / NJ / CT / PA 1 03-18-2014 11:17 PM
BRZ / F86 Sway bars timlewis82 Australia Classifieds 0 02-02-2014 03:58 AM
brz and fr-s sway bars different? 1010110 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-03-2013 02:43 AM
ST sway bars bmxhotsauce Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 05-09-2013 04:11 PM
FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! NJA Brakes, Suspension, Chassis 18 04-07-2013 07:00 PM
