Old 03-26-2014, 01:54 AM   #1
CX
CX's Avatar
Drives: FRS Monogram Series
How to keep DRL running even when the handbrake is on??
Hi everyone,
I just got the monogram frs recently, and I really enjoy the car.
I like the LED DRL very much, but I could not see it myself since everytime I pull the handbrake on then the DRL turns off.
Is there any way to keep the DRL running even when I have the handbrake on?
Thanks~
CX is offline   Reply With Quote
Old 03-26-2014, 02:22 AM   #2
Team STILLEN
Mark @ STILLEN
Team STILLEN's Avatar
Drives: 2015 Subaru BRZ
There has to be a sensor in the ebrake. If it is a multi duty sensor you just need to stop the signal going to the DRL's.
| Mark Dorman | Performance Specialist | markd@stillen.com| IG @Mark_STILLEN | www.STILLEN.com
Team STILLEN is offline   Reply With Quote
Old 03-26-2014, 02:47 AM   #3
CX
CX's Avatar
So I will try to revome all the leather covers on the brake and figure out which pin on the multi duty senor links to the DRL right?
Old 03-26-2014, 04:13 AM   #4
Team STILLEN
Mark @ STILLEN
There may only be a couple wires coming off the ebrake sensor and the spit occurs somewhere else in the harness. I haven't pulled all that apart yet so I'm not sure how it is wired.
Old 03-26-2014, 05:46 AM   #5
JakeG
JakeG's Avatar
Drives: MY15 GTS 6AT
Ehh, i wouldnt touch any of that yet unless you know what you are doing lol.
If it's too loud, you're too old.
JakeG is offline   Reply With Quote
Old 03-26-2014, 09:53 AM   #6
FR-Slide
Drives: 13 Whiteout 6MT
Is this just so YOU can see it when you want to get out and look at it? Or are you frequently using the handbrake while driving and don't like the lights going on and off?
I mean, just park the car on flat ground and leave it out of gear if you want to look at it. Or am I missing something here...?
FR-Slide is offline   Reply With Quote
Old 03-26-2014, 11:28 AM   #7
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
I kind of understand the OP. I was the same way with my BRZ. At the same time, like you said though. If you want to see the DRL, just park on a level surface, leave the car in neutral, and there you go
Eurasianman is offline   Reply With Quote
Old 03-26-2014, 02:20 PM   #8
wparsons
wparsons's Avatar
IMO, that's a big waste of effort just so you can get out and see the DRL a couple times.
flickr
Old 03-26-2014, 02:22 PM   #9
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
What I want is to have the DRLs on when I have the lights on. That is something I would be very interested in. I have a BRZ. I hate that they go off when the lights are turned on.
DrDuquette is offline   Reply With Quote
Old 03-26-2014, 02:34 PM   #10
codesplice
Elite Recognized Geek
codesplice's Avatar
Drives: 2014 DGM BRZ Limited
http://www.ft86club.com/forums/showthread.php?t=53111 should be able to take care of that for you. Yes, the thread is particularly about getting the "boomerang" LED lights around the headlights to come on with the DRLs, but you can play with different combinations and orientations of diodes to get the lighting setup that you want.
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+
codesplice is offline   Reply With Quote
Old 03-26-2014, 04:42 PM   #11
CX
CX's Avatar
I want to led to be on when I am parked +engine running with the handbrake on.
I put two golf clubs under the tires to stopp the car from rolling in my parking stall so I could see the LED myself, PITA!
Old 03-27-2014, 08:52 AM   #12
FR-Slide
I....what?
So you risked ruining your clubs just so you could see the LEDs?
How often are you really getting out to look at your car while running and on a hill? Why not just get a friend to sit in the car while you go stare at it? Or take a picture for the future? I'm just really missing the point here.
Like someone else said; just use the DIY's to make the LED strips stay on when your lights are on, then you can turn them on and leave the brake on whenever you want.
Old 03-27-2014, 08:57 AM   #13
DrDuquette
DrDuquette's Avatar
I....what?
Like you I don't understand the handbrake thing. To each their own. I like using the brake to blink the lights.
Anyone notice if you start out in 1st gear and lug the engine by accident the LEDs blink in and off. I find that interesting. BRZ only?
Old 03-27-2014, 09:13 AM   #14
codesplice
codesplice's Avatar
I think I've seen it mentioned that the DRL LEDs are pretty picky about voltage. When the alternator output drops (like when you lug the engine in first), the voltage also drops below ~14VDC and the lights go out.
The "boomerang" LEDs have a proper LED driver, so they don't get affected like that.
G+
Handbrake not working. MstrSHAKE Issues | Warranty | Recalls / TSB 44 01-19-2016 11:53 PM
RPM dip with A/C running BunnyRZed Issues | Warranty | Recalls / TSB 31 10-22-2014 09:56 PM
Leather Handbrake Boot Repair himbo Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 12-12-2013 12:45 PM
BRZ complete red stitched handbrake BRZED Interior Parts (Incl. Lighting) 1 10-09-2013 03:28 PM
Running 19's SocalBurt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 09-04-2012 02:45 PM
