Old 03-25-2014, 10:24 AM   #1
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Rear Facing Dashcam Install
I'm wondering if there's an elegant way to wire a dash cam facing towards the rear window.
One idea is to take a lead from the fuse box and wire it all the way back.
Is there anything in the trunk/rear seats that would be easier?
drewbot is offline   Reply With Quote
Old 03-25-2014, 11:31 AM   #2
mabviper
Drives: WRB BRZ
Where did you want to mount the camera, near the top or the bottom?
If you want it on the top, I suggest running power wires from the home link mirror connector right close to the interior light assembly. If you want it at the bottom, you can tap into the luggage compartment connector. I believe you need the orange wire but this one is always on. I can't find a line that's activated by the ignition in the rear.
mabviper is offline   Reply With Quote
Old 03-25-2014, 12:28 PM   #3
spyingwind
Drives: White '17 86
For my front facing dash can I tapped power from an empty fuse slot. Ran that through the firewall where I removed the sound tube. This way the camera had power all the time, it has a voltage cut off. You could just run it up under the pillar and roof.
spyingwind is offline   Reply With Quote
The Following User Says Thank You to spyingwind For This Useful Post:
drewbot (03-27-2014)
Prime Motoring's Forward Facing Precision 6466 FRS Drag Car PrimeMotoring Forced Induction 102 11-19-2015 11:12 AM
Show us your dashcam install Yruyur Electronics | Audio | NAV | Infotainment 33 02-19-2015 12:04 PM
Rear Armrest install Vides990 Cosmetic Modification (Interior/Exterior/Lighting) 8 03-09-2014 12:40 AM
Rear toe out after LCA install midnight23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 09-01-2013 05:46 PM
would rear-facing baby seat fit? ranisron BRZ First-Gen (2012+) — General Topics 17 02-27-2012 11:49 PM
