Old 03-25-2014, 07:23 AM   #1
djmm
djmm's Avatar
Drives: toyota
Why does 98/FRS?BRZ use premium 98 fuel?
I don't mean to troll, but I've always wondered why this car has to use premium/98 type of fuel when the matter of fact is the engine is not a performance car engine?
Anything special in the boxer engine which requires it to have only premium?
Pardon my ignorance if it seems like a stupid question.
PS - Having read the manual, it says you can use 95 unleaded quality fuel without giving giving adverse effect in driveability/durability... now I'm confused... Then what's the point of giving it 98, apart from the marginally better miles per gallon?
djmm is offline   Reply With Quote
Old 03-25-2014, 07:26 AM   #2
Shagaliscious
Drives: Firestorm FR-S (MT)
12.5:1 compression ratio.
The Following 10 Users Say Thank You to Shagaliscious For This Useful Post:
BRZfan (03-25-2014), Hardrock4445 (03-25-2014), hmong337 (03-25-2014), Hotrodheart (03-25-2014), hunter3232792 (03-26-2014), illest86 (03-25-2014), Mad1723 (03-26-2014), Mister (03-25-2014), strat61caster (03-25-2014), wrussi (03-25-2014)
Old 03-25-2014, 07:59 AM   #3
NahumCC
Drives: 2013 FR-S 10 Series
This right here is your reason. The higher octane is needed to increase the resistance to knock/pre-detonation in the combustion chamber.
For reference as to why the compression ratio of this motor is unique most factory FI cars run around a 9.0:1 from the manufacurer and for N/A motors around 10:1 or just slightly above that.
Direct injection has allowed compression ratios to be bumped up. The FA20 with a 12.5:1 is a first to me.
NahumCC is offline   Reply With Quote
Old 03-25-2014, 09:16 AM   #4
kevman_101
Drives: 2013 Scion FRS
It might not sound like a performance engine to you, but it kind of is. It pushes 100hp per liter. Take a Corvette ZO6 with 505hp. Devide 505 by 7L and you get 72hp/L. I`m pretty sure a Civic Si needs premium and most hot hatches as well.
With the ECU systems these days, you should be able to run regular and not do damage to the engine, unless you push it hard as it should sense detonation and work with the ignition, cams and fuel parameters to get rid of detonation. You will hurt the performance and fuel usage with regular, but if you`re stuck, regular should not kill the car in one single tank. Just don`t hit a racetrack with a tank full of regular.
kevman_101 is offline   Reply With Quote
The Following 2 Users Say Thank You to kevman_101 For This Useful Post:
Guillaume (03-25-2014), strat61caster (03-25-2014)
Old 03-25-2014, 09:18 AM   #5
GreenMonster
Just doing research
GreenMonster's Avatar
Drives: 03 Acura CLS 6MT
Hmm... didn't realize Australia had 98 and 95. Here in the states, our highest is 93 with 91 and 89 being the other choices.
GreenMonster is offline   Reply With Quote
Old 03-25-2014, 09:21 AM   #6
ZionsWrath
Thanks
ZionsWrath's Avatar
[ame="http://www.youtube.com/watch?v=ygBP7MtT3Ac"]Jeremy Clarkson POWERRR!!! Top Gear - YouTube[/ame]
Old 03-25-2014, 09:24 AM   #7
TM
TM's Avatar
Drives: DGM BRZ 6MT
Australia used a RON rating while the US uses AKI for octane. 98 RON is equivalent to 94 AKI.
TM is offline   Reply With Quote
The Following 2 Users Say Thank You to TM For This Useful Post:
DragonDriver5 (03-26-2014), strat61caster (03-25-2014)
Old 03-25-2014, 10:01 AM   #8
orlandorealtor
Drives: 2014 Scion FRS WHITEOUT
I think Chevron is 94
orlandorealtor is offline   Reply With Quote
Old 03-25-2014, 10:52 AM   #9
humfrz
Yes, I remember it well, it all started back in the 40s when the military wanted more powerful, thus faster fighter planes ....... ohhhh ..... sorry ..... carry on ....
humfrz
roddy (03-25-2014)
Old 03-25-2014, 01:44 PM   #10
Tromatic
Yes, I remember it well, it all started back in the 40s when the military wanted more powerful, thus faster fighter planes ....... ohhhh ..... sorry ..... carry on .... humfrz
A quick google shows the RR Merlin to have a 6:1 and a Wasp Major to be 6.7:1. ETA:
Interesting! High Compression!
Tromatic is offline   Reply With Quote
The Following User Says Thank You to Tromatic For This Useful Post:
humfrz (03-25-2014)
Old 03-25-2014, 01:47 PM   #11
Guillaume
Guillaume's Avatar
Drives: Exige S 240
The Merlin also had a hugeass supercharger
The Following User Says Thank You to Guillaume For This Useful Post:
humfrz (03-25-2014)
Old 03-25-2014, 01:55 PM   #12
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
It's already been mentioned, but it absolutely is a performance engine. 100hp/L naturally aspirated with a 7400rpm redline and a 12.5:1 compression ratio puts it solidly in that category.
chrisl is offline   Reply With Quote
Old 03-25-2014, 01:58 PM   #13
Tromatic
With a 6:1 compression ratio. The FA20 makes almost twice the power per liter as a Merlin.
Old 03-25-2014, 03:53 PM   #14
Guillaume
Guillaume's Avatar
Drives: Exige S 240
2030hp for the ultimate version of the Merlin, 75hp/l. That's LS territory 70 years earlier
Subaru Premium BRZ 86 & Premium Proud of Boxer Catalog & Broshure keioffice Miscellaneous 0 03-14-2014 08:10 AM
Odd Laws/No access to premium fuel? swift996 Off-Topic Lounge [WARNING: NO POLITICS] 6 02-06-2013 10:20 AM
Av Gas (low lead) fuel accidentally sold as Premium in NJ Dadhawk NY / NJ / CT / PA 6 12-19-2012 12:05 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
Premium Fuel riceracer8888 Scion FR-S / Toyota 86 GT86 General Forum 64 12-16-2011 10:27 AM
