Old 03-23-2014, 06:10 AM   #1
Junique
Drives: Gt-86 6mt
How to replace ecu / immobilizer system?
Hello,
I need to replace ecu of my car if u ask reason it's ecutek NA flashed by previous owner of car and now my car has hks supercharger kit and F-con.
Since I don't own a ecutek cable and dongle I can't upload factory map and I can't use the f-con properly, so since I don't want to spend more and since I have all engine/electronic of my second gt86 I thought would be cheaper ( but harder ) to replace ecu and immobilizer system, but I am not sure what else do I need to replace together with the ecu to make it work without any problem?
I have a donor car ( same year same spec, we just put gt-r engine on and built a track car ) so finding oem gt86 parts won't be hard for me cause they are laying in my friend's garage...
I just need a full list of necessary parts.
If somebody can help me I will be glad.
Thanks...
Junique is offline   Reply With Quote
Old 03-23-2014, 07:00 AM   #2
NickFRS
Drives: 2013 Asphalt FRS
Why not send email to ECUtek. + ECUtek is only 300 then find someone local with a cable if i'm not mistaken.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 03-23-2014, 06:52 PM   #3
sshole
You'll need to replace the gauge cluster with the matching one for your replacement ECU.
sshole is offline   Reply With Quote
Old 03-23-2014, 09:00 PM   #4
Junique
Drives: Gt-86 6mt
Hi there,
I also have the matching gauge cluster laying in my garage.
shortly i have all engine /electronic parts, all i need is full list of parts which has to be replaced.
Thank you
Old 03-28-2014, 12:36 PM   #5
Junique
Drives: Gt-86 6mt
Solved my problem, thanks to anyone who tried to help.
Old 01-14-2016, 06:09 PM   #6
Astroboy
Astroboy's Avatar
Drives: None
How'd you do it? I'm about to swap out my ecu and I was told that must do something else instead of just putting the new ecu in.
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 03-24-2017, 03:51 AM   #7
sabzi2007
Drives: Black gt86 2013
Hi mate
Ive notice you changed gt86 ecu kit from one car to another
Im in same boat as you and will be vey obliged if you can help me out and can provide me lists of parts you changed and programming if needed.
Really appreciate you help
sabzi2007 is offline   Reply With Quote
Old 07-28-2018, 12:44 PM   #8
steve99
To replace engine ECU
see here
http://www.ft86club.com/forums/showthread.php?t=102810
Replace the entertainment system 2014 BRZ Max1957 BRZ First-Gen (2012+) — General Topics 15 02-26-2014 05:45 PM
Just cooked my ignition amplifier, immobilizer, need advice Mwkincaid1 Electronics | Audio | NAV | Infotainment 4 01-23-2014 01:46 AM
URGENT - Engine Immobilizer System Malfunction! KevinTJH Scion FR-S / Toyota 86 GT86 General Forum 18 09-29-2013 12:52 PM
Is there a way to disable the immobilizer? schtebie Issues | Warranty | Recalls / TSB 5 09-22-2012 06:09 PM
replace the Ford Navigation system? megancheung Electronics | Audio | NAV | Infotainment 1 03-22-2012 02:51 AM
