Old 01-21-2014, 03:00 PM   #1
Mwkincaid1
Drives: Fr-s
Just cooked my ignition amplifier, immobilizer, need advice
Has anyone cooked there amplifier, immobilizer that wraps around the key ignition cylinder? I have ordered a new one, but I really don’t understand how this part works, does it need to be programmed? I feel completely in the dark on what this part does.
Mwkincaid1 is offline   Reply With Quote
Old 01-21-2014, 09:33 PM   #2
HapaHaole
Drives: Grocery cart
The OE repair manual does not state you need to program it, simply says to remove and install
Here is the copy.
1. INSTALL TRANSPONDER KEY AMPLIFIER
(a) Connect the connector.
(b) Attach the 2 claws to install the transponder key amplifier.
HapaHaole is offline   Reply With Quote
Old 01-22-2014, 08:33 PM   #3
Mwkincaid1
Drives: Fr-s
Awesome, thank you very much!!
Old 01-22-2014, 09:51 PM   #4
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
If you don't mind me asking, how did you do this?
kmbkk is offline   Reply With Quote
Old 01-23-2014, 01:46 AM   #5
Mwkincaid1
Drives: Fr-s
Ah yeah, well the short version of the story is, My son and I are trying to install a viper alarm with the idata link modules and set up the remote start. Well, we don't quite have the entire wiring diagram put together, so we thought it would be a good idea to take a constant 12v wire and test the ignition module. Well, from my best guess, one of the wires that goes to the amplifier immobilizer takes less than a 12v current or signal, and poof, we toasted the circuit board on the amplifier immobilizer. needless to say, we had to put the alarm install on hold until the car starts again, and then start over. And as a learning experience, i should do more research and probably ask the forum(s) if anyone else has been successful first before i take a constant 12v and start jumping it to other wires. good news, it's not the most expensive mistake I've made. the new piece was only $70 from Toyota, however the Subaru dealer wanted $90, so that's a good piece of advice to take away as well.
URGENT - Engine Immobilizer System Malfunction! KevinTJH Scion FR-S / Toyota 86 GT86 General Forum 18 09-29-2013 12:52 PM
Cooked my brake fluid!!! markitect Tracking / Autocross / HPDE / Drifting 18 07-11-2013 10:53 AM
Building audio setup. Need amplifier advice from the experts Kayzer Soze Electronics | Audio | NAV | Infotainment 69 06-04-2013 09:50 PM
Engine Oil Cooked? sierra Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 04-21-2013 07:03 AM
Is there a way to disable the immobilizer? schtebie Issues | Warranty | Recalls / TSB 5 09-22-2012 06:09 PM
