Old 03-21-2014, 04:39 PM   #1
pgeist
pgeist's Avatar
Drives: 2013 Black BRZ Limited 6MT
Grinding Gears + New Trans
Car started to grind gears shifting from 5th to 6th and various other methods during higher RPM shifts.
Brought my 2013 limited BRZ into my local dealer and within 10 minutes a tech drove with me in the car, felt the issues, and ordered me a new trans.
While this sucks.. I'm glad I was able to get a warranty replacement so quickly and easily with no hassle whatsoever.
Here's hoping for better luck with the new one.
Edit: have 8k miles on the car
Zeta Stage 2 Drop In + Red Silicone Tubing || Zeta SS Cat Back || DC Sports Cat-Delete Front Pipe || Torque Pro + MiniOBD Bluetooth || Fumoto F-108 Drain Valve || Konig Daylite Gold 17x7 +40 14.2lbs || Anarchy Motive Shift Knob
Future: Catted header, OEM Audio+
pgeist is offline   Reply With Quote
Old 03-21-2014, 11:59 PM   #2
humfrz
Well, let's hope the new transmission lasts longer .....
Do they have any idea of what went wrong with the old one .. ??
humfrz
Old 03-22-2014, 01:07 AM   #3
pgeist
pgeist's Avatar
humfrz
Nope.. they are a relatively small dealer that hasn't sold many BRZ's.. so I'm assuming they're just going to swap it and return the tranny to Suby for diagnostics.. but I doubt I will ever find out the true cause. The fact that they were able to get a trans so quickly leads me to believe that this is a somewhat known issue.
Old 03-22-2014, 01:50 AM   #4
humfrz
Or, maybe they just keep a transmission on hand as a "rebuilt" (one that they fill up with axle grease and banana peals) ..... and slap that one in the next car that has a transmission problem .... oh, never mind ..... that was an old trick .....
humfrz
Old 03-22-2014, 02:51 AM   #5
LuxuryVapes
Drives: 2013 Raven Scion Frs
Heard this cause was the trans fluid they used, knock on wood my car shifts smoothly and I even did a clutch pedal adjustment half the time I flat foot shift lol.
LuxuryVapes is offline   Reply With Quote
Old 03-23-2014, 10:07 PM   #6
shattered_memory
Drives: Satin White BRZ Limited
I had an issue with my tranny also. But it was a 4th gear grind at high RPM. I'm getting it warrantied this week. I have a friend with a FR-S with 30K miles on the car with no grinds whatsoever, so I don't think every tranny suffers from this problem.
shattered_memory is offline   Reply With Quote
Old 03-24-2014, 12:18 PM   #7
pgeist
pgeist's Avatar
I'm getting the new tranny installed Wedneday. Lets hope the grind doesn't return!
Mine almost always grinds while cruising in 5th and then shifting into 6th.
Old 03-25-2014, 12:25 AM   #8
evan
Drives: fr-s
A little birdie informed me that the Aisin 6MT in these cars is S-H-I-T
The only thing left on the table is a TSB
evan is offline   Reply With Quote
Old 03-25-2014, 10:02 AM   #9
Mister
Mister's Avatar
Drives: Firestorm FRS
Had the same thing happen to mine at similar mileage (6k). I have a thread that I started somewhere around here and the same deal, shifting from 5th to 6th. I had it replaced and so far no issues, now at 12k. Here's to hoping that is it.
Mister is offline   Reply With Quote
Old 03-25-2014, 10:42 AM   #10
WNDSRFR
Drives: FR-S,GTI
Same thing here. Got a new transmission and it works great.
No more grind.
Old 03-25-2014, 11:32 AM   #11
wheelhaus
wheelhaus's Avatar
Do you have some secret inside information or is this just hearsay/opinion?
There do seem to be a lot of people with tranny problems here on the boards, but if that's representative of total numbers, the vast majority are working perfectly fine.
wheelhaus is offline   Reply With Quote
Old 03-25-2014, 12:23 PM   #12
evan
Drives: fr-s
No secret info. Based on what I've heard recently about 86 owners taking their cars to the local dealerships here for problems with the MT (I don't believe them to be forum members), based on the consistent 1st gear, 2nd gear and 5th gear problems from multiple members on this forum and based on my most recent experiences with my own rock tumbler box.
Taking into account some opinions from a good source, I would not be surprised at all about a TSB being issued for the MT. Maybe in the next 6 months?? Who knows..
What I do know is that I'm never buying a 1st year car again. 2nd year maybe. 3rd year better.
Old 03-25-2014, 02:15 PM   #13
wheelhaus
wheelhaus's Avatar
This thread regarding a grinding 4th and 6th gear mentioned a TSB 03-71-13. Might be related if someone can link the TSB PDF.
Old 03-25-2014, 04:26 PM   #14
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
They're shit. Either that, or the fluids they used were shit. Mine ate the synchros by 5000 miles without any tracking or beating it up. When they drained it the fluid was filled with metal shavings. Numerous other people in here have had the same problem and tranny replacements.
DoomsdayJesus is offline   Reply With Quote
Speeds at each gears. mickey177 Engine, Exhaust, Transmission 10 08-25-2016 06:40 PM
fs: Perrin trans mount and whiteline trans bushing RWD_FR-S Transmission and Driveline 1 01-02-2014 05:34 PM
You know what really grinds my gears...... z3ro Off-Topic Lounge [WARNING: NO POLITICS] 7 10-10-2013 01:55 PM
2nd gears a b*tch Carbon420 Scion FR-S / Toyota 86 GT86 General Forum 32 01-29-2013 05:09 PM
Changing Gears Naughty AFRICA 10 01-09-2013 12:30 PM
