Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 01-08-2013, 06:40 AM   #1
Naughty
Drives: RunX RSi
Changing Gears
Hi Guys
Just a quick question for the 86 drivers.
I know the gears changing is notchy but do you get like a knocking noise when changing gears at low speeds. Like a noise from the diff?
Also when going over a speed bump i am getting a noise from the front.
Thanks
Naughty is offline   Reply With Quote
Old 01-08-2013, 07:26 AM   #2
Vic_RSA
The voice of reason...
Vic_RSA's Avatar
Drives: 2012 Toyota 86 6MT Standard
Try and be smoother on the clutch and change gear more slowly - mine is also a bit noisy - has gotten smoother with age and 6200 odd km. Is it a clunk going over bumps? It could be shock or strut related - I had that issue with my Corolla and after doing the alignment it disappeared - something was loose.
Vic_RSA is offline   Reply With Quote
Old 01-08-2013, 07:38 AM   #3
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
I think what you're describing is pretty normal for RWD cars.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 01-08-2013, 07:40 AM   #4
Naughty
Drives: RunX RSi
Ok i thought as much its normal for rear wheel drive. Plus the car is new so i want to run it in a bit s well to see if gets quite.
Yup i think i will get them to do the alignment.
Thanks Guys
Old 01-08-2013, 08:00 AM   #5
Alang
Alang's Avatar
Drives: 2013 Toyota 86 2.0 Std.
It does seem to be normal as both my cars do it. The 86 when it goes into first at stop I hear the clunk.
Adding power makes you faster on the straights, subtracting weight makes you faster everywhere - Colin Chapman
Alang is offline   Reply With Quote
Old 01-08-2013, 08:16 AM   #6
Naughty
Drives: RunX RSi
Ok cool, mine does the same.
Its the LSD
Old 01-08-2013, 08:38 AM   #7
Vic_RSA
Vic_RSA's Avatar
I must say one of the selling points of this car for me was the gearbox - it felt strong on the test drive. Having driven old cars with bad synchro you can really appreciate these. They seem to be built to handle punishment. Definitely built for the tuner's market.
Old 01-08-2013, 10:07 AM   #8
sav
sav's Avatar
Its the LSD
I don't think it's the LSD. My BM without LSD did the same.
I don't think I've ever driven a RWD car that goes into 1st at standstill with a bit of a clunk from the prop-shaft.
95RON SAV Tuned
Old 01-08-2013, 11:09 AM   #9
Vic_RSA
Vic_RSA's Avatar
Was waiting for that - my BM!
Mine too!
LSD shouldn't make a noise unless it's knackered.
Old 01-08-2013, 01:50 PM   #10
Naughty
Drives: RunX RSi
Cool, thanks for the feedback guys
Old 01-09-2013, 12:30 PM   #11
sieglapj
sieglapj's Avatar
Drives: Toyota 86 Red
I find that it was because I did not engage my clutch fully. Funny enough, I enjoy the clunk and tend to do it when I'm alone in the car. Ja u guys are right. The thunk from the speed bumps is normal. It's the heavy diff. If you fit the brackets/clamps that are featured on other threads, that will go away. Also they say that it adds to rigidity. I have seem gearbox, exhaust, door and may other re-enforcing brackets. They are all raving about them.
sieglapj is offline   Reply With Quote
Hearing a squeak whenever I accelerate and shift gears slowbrz Issues | Warranty | Recalls / TSB 7 05-29-2022 08:52 PM
Speeds at each gears. mickey177 Engine, Exhaust, Transmission 10 08-25-2016 06:40 PM
What really grinds my gears! CircuitJerk Off-Topic Lounge [WARNING: NO POLITICS] 124 04-01-2013 08:45 PM
Top Gears - Worst Car in the World KlafKoon FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 12-02-2012 09:20 AM
