Old 03-18-2014, 04:56 PM   #1
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Rotrex SCs' in regards to (Elevation & Temp changes) Affects?
Greeting 86 friends
So I have been following the FI Section since forever lol..
In my near days coming I will be going FI. I have narrowed down for FI on the SC side to being the Rotrex units as my favourite thus far. And for TC Avo or Ptuning. The units like Avo for TC, Innovate for SC etc and some others I understand are done MAF tuning vs SD.
My questions or concerns with the Rotrex units comes from seeing repeated results but also comments on them being SD tuned.
Now bear with me on my (noob) understanding of how they the Rotrex have been being tuned. I understand that for them to be running optimum that they require SD tuning. And also to my understanding that means the ECU has less adaptability to both elevations and also temperature variance. Is this in fact correct?
Situation: I live where my elevation of residence is 3000 feet above sea level. When I go for a drive in the mountains which I frequently do in summer the elevation changes are from 3000-4400 feet above sea level. The temperature changes even in mid summer can vary from 35 degrees F in am to 90 degrees F by late afternoon, and this is no joke it can be that much.
So what I am trying to determine is how that will affect the performance of a rotrex or the car in general and if a SD tune is in fact 100% safe on rotrex for (MY SITUATION) being the high elevations and changes and temps?
I see most folks here are at sea level or damned close with these units and unless they do a country wide tour they may not even experience what I am speaking of to know any different. However trying to collect some information and possibly comments from folks that live in higher altitudes and their experience with the Rotrex units. Last thing I want to do is (F) a motor without even getting on it cause the unit I install may not be correct given my geographic location.
The Following User Says Thank You to OICU812 For This Useful Post:
OjiGeorge (03-18-2014)
Old 03-18-2014, 05:07 PM   #2
wheelhaus
wheelhaus's Avatar
This is relevant to my interests.
I'm looking at the same kits (mostly leaning toward The JR Rotrex kit) and I live in Denver (5000-7000ft around the city and foothills, up to 13,000ft for some of the highest roads). We also have wild temperature swings on any given day, where the morning could be below freezing, and the afternoon may be over 70°F. Or 100°+ in the city, but 50°F up in the hills.
wheelhaus is offline   Reply With Quote
Old 03-18-2014, 05:41 PM   #3
enivid
enivid's Avatar
Drives: WRB JR BRZED
I'm at 4200+ feet. I'll be on a dyno in a couple weeks.
enivid is offline   Reply With Quote
The Following User Says Thank You to enivid For This Useful Post:
OICU812 (03-18-2014)
Old 03-18-2014, 07:58 PM   #4
The Jackson Racing kit was heavily tested in California and Colorado. The Factory Tuned version of the kit will have zero trouble working in high altitude conditions.
Old 03-18-2014, 09:08 PM   #5
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
As CSG Mike mentions, the Jackson Racing Carb Tune Kit has spent a lot of time in CO... a lot... without any issues.
+1 for Jackson Racing
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
The Following User Says Thank You to *LongFella For This Useful Post:
OICU812 (03-19-2014)
Old 03-18-2014, 10:16 PM   #6
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
How about on a hill climb?
TBH, this concern was the main reason I went TC instead of the KW kit.
OjiGeorge is offline   Reply With Quote
Old 03-18-2014, 10:37 PM   #7
CSG David
CSG David's Avatar
The JR CARB Tune Kit has been through extensive testing on the same tune to validate all the parameters and ensure it will pass CARB with no issues. Hill climbs, high altitude and cold weather testing in Colorado (below freezing), desert testing in Death Valley of upwards of 125F at way below sea level, etc. all on the same tune due to CARB. It sounds all crazy, but everyone who actually has this kit and tune installed on their cars will verify this statement.
The Following User Says Thank You to CSG David For This Useful Post:
*LongFella (03-18-2014)
Old 03-20-2014, 12:05 AM   #8
mashal
DADA
mashal's Avatar
Drives: 2013
Sub'd, I was thinking of the same kits as you. I keep going back to Jackson, will hopefully make the move soon.
mashal is offline   Reply With Quote
FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) AtlasMick Interior Parts (Incl. Lighting) 2 03-31-2015 05:47 PM
effects of elevation StormTrooper Engine, Exhaust, Transmission 1 01-27-2014 12:26 AM
29 degrees F in Texas--near sea level elevation dave77 Scion FR-S / Toyota 86 GT86 General Forum 28 01-06-2014 12:57 PM
STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB ziptiedae86 Interior Parts (Incl. Lighting) 0 10-29-2013 11:50 PM
Boost gauge off at elevation gdrider77 Forced Induction 7 09-25-2013 01:32 PM
