Old 03-16-2014, 06:21 AM   #1
Kodename47
Kodename47's Avatar
Drives: UK GT86
Fuelling Issues (ECUtek ROM)
I thought I'd share some symptoms and asks for ideas and advice from some of the more experienced. 2 issues not related but occurring at similar RPM.
1st of all the PI seems to cut off for a brief period. It has no impact on the resultant AFR so it's not an issue but it's a tad strange. The PI/DI ratio table is as below:
But this is the injector open times:
Any ideas?
The other issue is that the car goes lean momentarily between 4.2-4.6k:
You can see the commanded AFR. The point it goes lean is bang in the middle of 2 MAF scalar points, the voltage points sit almost exactly at 4.2 and 4.6k RPM, so it's not a MAF issue. My initial thought is that as both intake and exhaust cams ramp up then the overlap increases as below:
My questions:
- Is the AFR actually true? You can see from the top images that the fuelling hasn't changed through that range. Is there a chance that the overlap is causing fresh air charge going through the cylinder causing leaner readings?
- Could the PI/DI ratio have an impact? I've moved the ratio back to stock from the tables above. The PI is showing as 50% in that range, but OEM is 100% DI. Could that help?
- Would just enriching out the fuelling table at 4400 be the right way to improve this?
Any other ideas?
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-16-2014, 06:58 AM   #2
Mark@Abbey m/s
Drives: GT86 in Orange
The PI shut down but the fuelling is added via the direct injectors.
The switching between injectors is as the car was tuned from the factory.
Mark@Abbey m/s is offline   Reply With Quote
Old 03-16-2014, 03:22 PM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
But at these loads I would expect it to be 100% DI between 2400 and 4800 as per the top map, not between 4500 and 5000. It doesn't really tie in with either map or be an interpolation between either.
For reference the cold map is stock, the warm and hot maps are both as the lower map shown.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-16-2014, 11:50 PM   #4
Revolutions Performance
Drives: 2013 SWP BRZ RP Turbo Kit
What's the load being logged when this happens?
Revolutions Performance is offline   Reply With Quote
Old 03-17-2014, 04:13 AM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
.: Stealth 86 :.
Kodename 47 DJ:
Oil issues with my avo brz...help!!!!! brz2013 Forced Induction 22 10-19-2016 11:03 AM
ECUtek issues 20firestorm13 Engine, Exhaust, Transmission 12 05-23-2013 11:09 PM
Anybody Have Zero Issues? Don Ivey Scion FR-S / Toyota 86 GT86 General Forum 129 03-25-2013 01:14 PM
more issues after CEL fix.. DrewZ926 Issues | Warranty | Recalls / TSB 2 11-07-2012 08:15 PM
Anybody with no issues? tdoggy57 Scion FR-S / Toyota 86 GT86 General Forum 49 08-04-2012 03:41 PM
