Old 03-18-2013, 12:27 PM   #1
kingping
Drives: 2013 Subaru BRZ Premium, manual
Driver door alignment issue--fixed
I noticed the drivers door upper hinge area was mis-aligned with the front quarter panel, enough so that the door edge would just start to touch the panel when opening/closing. It was almost as if someone had sat on the door when fully open. (4500 miles, pampered and absolutely no door abuse on my end.) Apologies for no pics--it would have been easy to show...
To their credit the local dealer had it fixed within an hour with the body shop doing "re-alignmnet" on the door. I wondered if this was at all common--the service writer also wondered if there was info in the "forums" about this. Ahh, the joys of a first year model!
kingping is offline   Reply With Quote
Old 03-18-2013, 12:53 PM   #2
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
don't think i've heard of anybody else with this issue, but glad to hear you got it fixed!
mezdup is offline   Reply With Quote
Old 03-18-2013, 01:27 PM   #3
DieselxIndustry
Drives: 2013 Firestorm FR-S
I have a gap on the passenger side door to the fender. I haven't had a chance to go back in but there are others who have had this problem.
DieselxIndustry is offline   Reply With Quote
Old 03-18-2013, 01:29 PM   #4
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Is THIS similar to what you get?
Sigh-on-Rice is offline   Reply With Quote
Old 03-18-2013, 01:37 PM   #5
kingping
No. I saw that while searching around but that's not my issue.
Imagine if the leading upper edge of the drivers door were protruding outward when closed, almost acting like a small air scoop. Then, when closing the door, it would make contact with the adjacent fender edge mid-swing. Just picked up the car and the hinge/door orientation is perfect. I assume it was a "loosen hinge/alingn gaps/tighten hinge" type of fix...
Old 03-18-2013, 04:38 PM   #6
DieselxIndustry
I have what Ro Ja has.
Old 10-14-2013, 11:33 AM   #7
Kids Heart
Kids Heart's Avatar
Drives: 2013 BRZ Limited SWP
My passenger door on my BRZ has a gap. No rubbing so ill wait for my 7k service to see what the dealer can do
Kids Heart is offline   Reply With Quote
Old 06-23-2014, 01:15 PM   #8
Kristian
I have the same issue with my 2013 FR-S on the driver's side. I took it in to the dealer today so we'll see...
Kristian is offline   Reply With Quote
Old 06-23-2014, 01:32 PM   #9
jeffchap
jeffchap's Avatar
Drives: 2013 Scion FR-S Raven 6MT
I leaned over mine once to clean something off the windshield, and apparently pushed in the fender so that it rubbed the front edge of the door when opening and closing as you described. I just opened the door again and grabbed the edge of the fender and pulled it back out. There was a fair amount of play in it, such that I pulled it out too far and had to push it back in a little to line it up properly.
The rubbing even took off a little paint on the front edge of the door, but I touched it up so that you can't even tell now. And I'm very careful not to lean into the fender any more.
Sent from my RM-820_nam_att_100 using Tapatalk
Stay squatchy, my friends
jeffchap is offline   Reply With Quote
Old 06-23-2014, 04:48 PM   #10
Kristian
Hmm... Interesting. The dealer is having a body shop check out my car in this case (I didn't lean on it).
Old 06-26-2014, 07:28 PM   #11
Kristian
Update - Scion of Kirkland had it fixed for me! I can't even tell there was paint wear or misalignment of the door with respect to the quarter panel now.
Old 06-29-2014, 10:51 PM   #12
CIAGDDS
Drives: BRZ-L
I had the same issue. I fixed it by gently pulling the front quarter panel out at the door seam. Perfect match now.
CIAGDDS is offline   Reply With Quote
Old 06-30-2014, 12:13 AM   #13
markw
Drives: 2014 FR-S
This is actually pretty common with new cars. It used to be that the dealers would have to align the panels when they received the cars. With todays closer tolerances they only generally do it when a customer requests it. If you have any panel alignment issues the dealer will usually be good about fixing it.
markw is offline   Reply With Quote
Old 09-03-2017, 02:02 PM   #14
Webxman
Webxman's Avatar
Drives: 2015 Scion Frs
Door not latching
Driver side door will not latch without lifting it up it's almost like it's off alignment any fixes for this?
Webxman is offline   Reply With Quote
alignment, door
Driver side door handle lordtakuban Cosmetic Modification (Interior/Exterior/Lighting) 19 06-19-2014 01:30 AM
FS: FRS (oem) Driver/Passenger Door Panels NRG x FRS Interior Parts (Incl. Lighting) 3 11-28-2012 12:22 AM
Car and Driver December issue whaap Other Vehicles & General Automotive Discussions 4 11-06-2012 11:41 AM
Door miss alignment after wind caught it Baker Issues | Warranty | Recalls / TSB 6 09-24-2012 10:22 PM
Door Rattle Issue DriftEightSix AUSTRALIA 4 06-28-2012 01:11 AM
