Drives: 2013 Asphalt FR-S/2003 Honda Accord
Cold air intake question
Hello guys.
I recently installed aftermarket cat back exhaust (ARK DT-S) and just love the sound and power out of it ![]() but I have a question. is it MANDATORY to put cold air intake? my friend told me "just saying, its common physics : increase in output potential with no increase in intake volume does not give you the power, your going to damage your engine" and stuff stuff. if any of you who installed exhaust but intake, i would like to know what happened to your car. Thanks in advance |
Fanboy
Drives: 2013 ultramarine frs
Get a drop in filter or wait for grimmspeed to finish their intake. Most are snake oil. Stock intake is quite good.
I'm done helping those who won't help themselves.
TL;DR: ![]() -Duke |
You shouldn't need an aftermarket intake until you need to exceed what the OEM intake can accommodate. A drop in filter as Duke mentioned should be plenty. Too many intakes provide a small bump in power because they change how the MAF sensor reads the airflow, causing the ECU to inject slightly more/less fuel than what it's calibrated to use. Once the ECU is recalibrated (tuned) to read the new airflow correctly, the tuner can make accurate changes in the fuel tables to make power safely.
what's drop in filter? some kind of intake??
Drives: 2015 WRX
It's just a replacement filter made of a different material than the OEM piece. Most filters are made of a paper material, some are sheet foam, some are cotton embedded in a screen mesh. Paper can filter the best, cotton mesh can flow the best regardless of it's material. Most manufacturers say theirs is the best. Mesh filters can often be "washed" and reused, but of course they're the most expensive. I've seen some mesh filters go for $100+.
Custom User Title
Drives: Asphalt FR-S MT
Find a new friend.
lol
| Best cold air intake | natesparxxx | Engine, Exhaust, Transmission | 31 | 05-31-2021 05:04 PM |
| AEM Cold Air Intake | L3P47 | Engine, Exhaust, Transmission | 27 | 03-03-2021 12:59 PM |
| cold air intake vs short ram intake ? | tnt | Engine, Exhaust, Transmission | 5 | 02-02-2014 12:43 AM |
| cold air intake? | carbonBLUE | Engine, Exhaust, Transmission | 72 | 09-30-2013 12:56 PM |
| FRS AEM Cold Air Intake | KenAEM | Engine, Exhaust, Transmission | 28 | 10-24-2012 12:48 PM |
