Old 05-10-2012, 07:01 AM   #1
speedrye
Drives: White
Subaru vs Toyota bolt/nut sizing
I searched and didn't find anything on this, so... what size bolts/nuts are common on Subarus? I've always worked on Toyotas and know they use the 10mm, 12mm, 14mm and 17mm on almost every part of the car. For you Subaru guys, what are the standard sizes you use? I'm just wondering if I'm going to have to modify my standard tool kit or not.
speedrye is offline   Reply With Quote
Old 05-10-2012, 08:16 AM   #2
SlateR
SlateR's Avatar
Drives: 1967 Chevrolet C-10
You might want to post this in the BRZ forum if you haven't already.
SlateR is offline   Reply With Quote
Old 05-10-2012, 09:24 AM   #3
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
yes 10, 12, 14, and 17 is very common on Subaru's as well. There are some parts that require special tools (differential oil plugs, clutch fork bolt) but you can take apart 99% of the car with those 4 sockets. I had to take off my rear bumper and tail lights this weekend and only used 8, 10, and 12, and a flathead screwdriver.
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 05-10-2012, 11:06 AM   #4
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Sounds just like a Honda too And Nissan.. and Mazda..
Better than the Torx head obsession the German cars seem to have.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-10-2012, 04:54 PM   #5
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
Standard JIS metric bolt heads are usually used in most Japanese vehicles, which makes them very similar across most Japanese brands.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 05-10-2012, 05:33 PM   #6
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
19mm for the wheels...
14mm all over
12mm all over
10mm all over
8mm all over
17mm for some suspension components
that will fix about 90-95 % of everything that ales you..
Bill
Scooby South is offline   Reply With Quote
Bolt Pattern, Wheel Hubs and Studs Jeff Lange Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 03-08-2012 02:49 AM
The wheel bolt pattern is... quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 193 02-29-2012 06:04 PM
Replace stock hubs with different bolt patern ones? ahausheer Other Vehicles & General Automotive Discussions 10 02-07-2012 12:24 AM
Plus 0 tire sizing Brzer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 01-30-2012 08:15 PM
Estimated HP gains - bolt on mods and reflash? ahausheer Engine, Exhaust, Transmission 207 01-14-2012 06:14 AM
