Old 03-05-2014, 11:59 AM   #1
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Shifter bushing sleeve/bolt tolerance
For those guys that have installed a rear shifter bushing, what was the tolerance between the m8 bolt supplied and the sleeve? I picked up an energy suspension bushing and the tolerances... are... well....... excessive. Is this the case with the perrin or kart boy bushing?
The sleeve diameter reads .385", the bolt reads essentially .315" (8mm). I feel a .070" clearance would allow for a lot of vertical play. im considering picking up 3/8" shoulder bolts to reduce the clearance. Thoughts or suggestions?
@FT-86 SpeedFactory would you be able to shed light on this for me?
supramkivtt2jz is offline   Reply With Quote
Old 03-05-2014, 11:53 PM   #2
twag4
Drives: frs
The bushing is to keep the bolt from compressing the new shifter bushing. The fact that the bolt isn't snug inside the bushing is inconsequential. The bolt and washer will tighten against the bushing and keep the bushing from sliding around. The bushing will be pressed by the bolt and washer into the surface where the bushing bolts to. You don't have an issue here. Install and enjoy your improved shifter!
twag4 is offline   Reply With Quote
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
Shifter TSB 03-71-13 v. Perrin Rear Shifter Bushing swansons Issues | Warranty | Recalls / TSB 4 02-02-2014 02:27 PM
Shifter Bushing Vlady Want-To-Buy Requests 1 10-29-2013 05:39 PM
Whiteline transmission bushing and Perrin shifter bushing review. Superhatch Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 12-09-2012 08:40 PM
Does the STI Rear Shifter Bushing fit the BRZ/FRS? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 08-27-2012 03:48 PM
