Drives: s2000
Drop something in the engine bay
Was installing HID and accidentally drop the stupid plastic bulb cover down into the bottom of the shield, does anyone know how I can take it out, or would it just roll out from driving?
Drives: 2013 MT Asphalt FRS
You need to take it to the dealership ASAP...
When you say shield, you mean the splash guard under the header? It just is a few bolts and clips to take that off.
Drives: 2014 Scion FRS
Haha I did the same thing with a hose clamp once. Luckily it was close enough to one of the openings in the skid plate underneath that I could get a hook tool through the gap and pull it ahead. Then from the top I was able to use the same tool to hook it again and pull it up and out. What a bitch that was.
Anyways, definitely get it out of there before you drive or it will likely melt from the heat from the headers. Best case is that it just smells like burnt plastic. Worse case is that it starts a fire. |
Senior Addict
Drives: 86 GT
raise the front end from the middle jack point, as high as the floor jack can go. Then start tapping the shield and pray the bulb cover rolls off. It works for me when i accidentally dropped a bolt and it landed on the under tray.
Otherwise, just remove the tray.....i think it's only held by six bolts and a handfull of clips. |
Just drive it
Drives: 13' FR-S
Is this question really necessary to ask...? If you drop something, get down to the car, raise or whatnot, remove the bottom cover, find the plastic..
| **Vicious LED -PRICE DROP: Password:JDM Engine Bay Dress Kits Various Color Choices** | Vicious LED | Engine, Exhaust, Bolt-Ons | 18 | 09-28-2013 03:06 AM |
| FINALLY engine is broken in...engine/tranny smell? | denverizzles | Engine, Exhaust, Transmission | 18 | 09-15-2013 08:12 PM |
| Drop it Like its Hot! *Lets See Your Drop* | VIXEN | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 92 | 09-07-2013 02:53 AM |
| Who is going to buy the FRS DROP DROP Shop? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 10-18-2012 05:45 PM |
| Engine sputtering while idling with check engine light flashing, WTF | speedy racer | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-27-2012 06:50 AM |
