Old 03-03-2014, 08:37 PM   #1
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
Talking 400hp on pump gas
[ame="https://www.youtube.com/watch?v=BQYd4abTsq4"]Subaru BRZ Turbo 412hp Dyno - YouTube[/ame]
I was making 366hp/278tq at 16psi prior using a manual boost controller. I felt like I was getting some inconsistent boost sometimes, so I switched to a COBB 3 port electric boost solenoid. This allows for the ECU to control the boost, and in turn allowing for different levels of boost on different maps. The boost also builds a little quicker now.
Currently,
Map 1: ~7psi, 267hp / 204tq
Map 2: ~21psi, 412hp / 308tq
Garrett T3/T4 .60 trim
UEL manifold
2.5" exhaust
It starts building boost around 3-3.5k. It hits 10psi by 4k, 20psi by 5k.
R/T Tuning (vendor here) in PA has done all the tuning and worked out a lot of the hiccups associated with this setup. I can't say enough good things about these guys. They kick ass.
The weather isn't letting me really drive it hard since the pavement is so cold. I made a couple pulls in 5th gear (where I had some traction) and to say it is fast would be an understatement..
I am building a shortblock this summer so that I can run more boost more safely. Hopefully some well tested cams will be out by then so I can play with them as well.
Obviously this is pushing it with these motors. (21psi, pump gas, 400hp, stock internals...)
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 03-03-2014, 08:40 PM   #2
johnnyb305mia
Drives: 14 BRZ Limited
enjoy sir!
johnnyb305mia is offline   Reply With Quote
Old 03-03-2014, 08:40 PM   #3
Frs300
Frs300's Avatar
Drives: Pile of junk
Impressive is all i can say
Frs300 is offline   Reply With Quote
Old 03-03-2014, 08:41 PM   #4
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
Awesome!
Jesse@JDLAutodesign is offline   Reply With Quote
Old 03-03-2014, 08:43 PM   #5
mrk1
Drives: Sterling BRZ Ltd
Sweet, I don't have e85 here so it's great to see someone else staying on pump! What compression are you going with on the built block?
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 03-03-2014, 08:48 PM   #6
woode
Boosted Member
woode's Avatar
I haven't made my mind up. To be honest, I want to stay as high of compression as possible. I will probably just bump it down a little bit, maybe 11.5. The bigger reason for building it is the switch to forged pistons/rods.
My "goal" is to have a powerband of somewhere in the range of 5-8k rpm and hit at least 500hp on pump gas. Obviously lots of changes will be happening to her for that to happen.
Old 03-03-2014, 08:55 PM   #7
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
Impressive!
Sent from my Nexus 7 using Tapatalk
pixel67 is offline   Reply With Quote
Old 03-03-2014, 09:12 PM   #8
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Occam's Razor if I may say so.
slicktop is offline   Reply With Quote
Old 03-03-2014, 09:36 PM   #9
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
How long will the block last with 21psi on 98(RON) 93(AKI)?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 03-03-2014, 09:53 PM   #10
woode
Boosted Member
woode's Avatar
No idea. There hasn't been a lot of testing at high boost on these stock motors with pump gas.
The direct infection helps with keeping things cool inside. No knock at 21psi at 12.5:1 is pretty good I think. As far as how the stock cast pistons hold up...
Old 03-03-2014, 10:00 PM   #11
JerryMichaels7
Drives: Whiteout FRS
this is 93??
life's greatest stories usually start with the words, "fuck it!".
JerryMichaels7 is offline   Reply With Quote
Old 03-03-2014, 10:01 PM   #12
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
You know, JE makes 13.5:1 pistons in any size you need. No need to lower the compression. If anything you can slap those suckers in, dial down boost, and still make more power.
Tuned by Delicious Tuning
http://www.delicioustuning.com/node/209
Kraftwerks Supercharged
Zach3794 is offline   Reply With Quote
Old 03-03-2014, 10:02 PM   #13
woode
Boosted Member
woode's Avatar
Originally Posted by JerryMichaels7 View Post
this is 93??
Yes
Old 03-03-2014, 10:08 PM   #14
nelsmar
My flickr - Canibeat
Local magazine scout
400HP Toyota GT86 GT4 Racer by GPRM Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 46 04-10-2015 09:31 PM
Nissan 400hp 88lb turbo 3 banger Anthony Other Vehicles & General Automotive Discussions 3 01-27-2014 11:51 PM
400hp build and other turbo questions. Ludacrits Forced Induction 22 10-26-2013 09:01 AM
400HP Firestorm Red FBM Kit FullBlown Forced Induction 166 10-16-2013 05:54 PM
E85 400hp mark Fabron757 Forced Induction 26 06-20-2013 01:41 PM
