Old 03-03-2014, 02:45 PM   #1
gramicci101
Off Topic
Staggered tire question
Good people of the Wheel and Tire section,
It's my turn to ask a stupid question! I did search already, and I've been all over most of the forum by now, I just wanted to nail down a few more things before deciding on staggered vs. square for my car.
First, my driving style. I'd say it's 60% commuting, 35% spirited, and 5% mountain/canyon roads. No autocross, HPDE, or track days. I'm trying to choose between 18x8.5+48f/+40r with 235/40's all around, and 18x8.5+40 with 235/40's on the front and 18x9.5+40 with 265/35's on the back. The car will be lowered on RCE Yellows, so 20mm down.
Now, my question. Aside from looking cool, and it does look cool, are there any benefits to running staggered tire widths?
Are there any cons to running staggered tire widths? Logic suggests that there will be more understeer, but comments from other users have said that there is minimal, if any, additional understeer, and even if there was it could be compensated for by using different swaybars. The car will have more rotational mass, so it'll be a little slower. But I'm not at the track trying to eke out that last tenth of a second, so will it really affect me?
If I've missed something obvious, feel free to point and laugh.
Thanks,
jeff
Old 03-03-2014, 04:28 PM   #2
FunCon5
FunCon5's Avatar
I have staggered tires. 225/45 & 245/40. I am going to go 245 all around here in a few miles. (the fronts are almost done)
I had staggered rims & tires on my S2000 also. The S2000 came staggered, unlike the FR-S.
Here are some of my thoughts...
I would either go 225/40 all around on the 8.5's or 245/35 all around. 235/40 is taller, and a rare size. (OK semi-rare)
Staggered wheels and tires look awesome! I like wider tires on the back. If this is the look you are going for, Do It!
I don't think a stock FR-S (200hp) is going to benefit from being staggered or 265 width tires. (you said no AutoX or anything like that)
A staggered setup is going to lower your mpg and acceleration. The rear wheels and tires are going to be heavier. I have listed a few sizes below of Michelin Pilot Super Sports. As you can see the 265 is 3lbs heavier, the 9.5 is also X-amount lbs heavier. So the rear is, lets say 5lbs heavier, you will notice this compared to a lighter weight wheel and tire combo.
GOOD LUCK!
MPSS tire weights: (per tirerack)
225/40/18 = 22lbs
235/40/18 = 23lbs.
245/35/18 = 23lbs.
265/35/18 = 26lbs.
This tire calculator really helps get the same size (or close enough) outside diameter tires for a staggered set up. Or for plus sizing.
http://www.discounttire.com/dtcs/infoTireMath.dos
tire weight Linky:
http://www.tirerack.com/tires/tires....omCompare1=yes
FunCon5 is offline   Reply With Quote
Old 03-03-2014, 04:51 PM   #3
gramicci101
Off Topic
The 235/40 is .8 inches greater than stock in diameter. A 235/35 is .2 inches smaller than stock, but they're even harder to find unless I want to spring for Pirelli P Zeros. Interestingly, the 265/35 and 235/40 are .1 inches different.
For 225/40 I'll need to get an 8" front wheel, which isn't a problem. They're about .4 taller than stock. I'd get 255/35 in the back, as they're right about the same overall diameter.
The benefit of doing 245's all around vs. 235/265's would basically be handling?
Old 03-03-2014, 05:38 PM   #4
FunCon5
FunCon5's Avatar
Yeah, forget the 235/35 size. A 225/40 will fit fine on a 8.5. I have run this size tire and wheel on my Acura RL and Acura legend back in the day.
This forum member has a staggered set up with 225/40 255/35 tires on 8.5 and 9.5's. I think the tires fit nicely on the wheels.
http://www.ft86club.com/forums/showthread.php?t=58897
What rims are you thinking about?
A 245 all around will enable tire rotation and be lighter weight. The staggered setup is going to be for looks.
And honestly, the difference in handling will be small. I think that it will be imperceptible during casual driving.
Rolling resistance and tire weight does affect MPG. When I went from the 215/45 to a 245/40 my mpg went down about 3mpg. Something to consider...
Old 03-03-2014, 05:58 PM   #5
gramicci101
Off Topic
I've looked at that car a fair amount, and most of the other cars on the wheel fitment guide in my range. I've also looked at Shiumai's car, since he's got the same size wheels, tires, and drop I was thinking about. Same car color, too. link
I think I may go with 245s all the way around. I'm looking at bronze rota torques. Staggered would be 18x8.5+40/18x9.5+40, square would be 18x8.5+40 and maybe spacers on the back.
Old 03-04-2014, 03:42 PM   #6
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
I've run staggered on my last 2 cars, there's been no real downside.
Since you can't rotate you buy rear tires twice as often, but fronts half as often.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 03-04-2014, 05:20 PM   #7
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Or you can just take off the rear tires and rotate them. As you see on my pic my left side is worn out more so im just going to go to a tire shop and have them switch the tires around, better deal then buying new tires.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Staggered tires and STS Tire & Battery woode BRZ First-Gen (2012+) — General Topics 9 01-30-2014 11:14 AM
staggered wheels question. djleepanda Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 08-14-2013 05:15 PM
Another staggered question Grymm86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 06-20-2013 04:39 PM
staggered setup - how's the tire wear? cfordart Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 04-21-2013 12:27 PM
Widest rear tire for a staggered setup? Jeff Lange Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 05-22-2012 08:52 PM
