Old 08-14-2013, 03:32 PM   #1
djleepanda
Panda
djleepanda's Avatar
Drives: 2013 Subaru BRZ
staggered wheels question.
I am leaning toward getting a Enkei RPF1 and was wondering if 17x8 and 17x9 (both +45) would cause any issues?
Also, what would you recommend for tire sizes for these fitment? My car will not have any suspension upgrades. Thanks.
Other suggestions are welcome.
djleepanda is offline   Reply With Quote
Old 08-14-2013, 03:50 PM   #2
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
Tons of other threads with this question, but why stagger if you don't need to? +45 offset wheels look good in the front and back at the right width. True that with no suspension a 9 inch wheel in front is going to rub on the stock strut/spring ... but if you can afford at least some lowering springs you can squeeze in a 9 inch wide front.
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
Old 08-14-2013, 04:41 PM   #3
Ammonia
Ammonia's Avatar
Drives: Whiteout FRS, Audi A4, 135i (sold)
Non staggered tends to poke in the front. I know for me that was the reason I went staggered, for flush front and back. I'm OCD about avoiding pokey tires though, so it may not even register or bother other ppl.
OP, your set-up should be just fine.
Ammonia is offline   Reply With Quote
Old 08-14-2013, 04:47 PM   #4
djleepanda
Panda
djleepanda's Avatar
Thanks for the input guys. One more thing... What tire sizes should I look into? should i get same all across?
Old 08-14-2013, 05:15 PM   #5
Ammonia
Ammonia's Avatar
Staggered rims usually call for staggered tires. I personally went with 225/40/18F and 255/35/18R.
Another staggered question Grymm86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 06-20-2013 04:39 PM
Ok to have non staggered wheels but staggered tires? taimysho0 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-21-2013 11:57 PM
Staggered Setup Question Chewie4299 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 04-08-2013 09:33 PM
why staggered wheels? koyv90 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 46 02-28-2013 06:02 PM
staggered and unstaggered wheels 86 FRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 09-06-2012 04:27 PM
