Old 03-01-2014, 07:21 PM   #1
dbrandt01
Drives: none
DIY: Removing interior trim
I've been searching and I've always seen posts about people asking to remove interior pieces but haven't seen a how to. Unless I'm blind and just plain missing it. If this has been done, feel free to delete it.
So with that being said I made this video out of boredom today and hope it's clear to understand. Hope it's enough to help someone even a little bit. I didn't remove the trim on the steering wheel and around the AC controls.
Items need: Flat head screw driver helps getting the pieces off.
Phillips screw driver to get the traction control buttons and shift boot off.
Didn't take pictures, but for the trim around the AC Vents are simple. I used the flat head screw driver between where the trim connects and it pops right off, To put them back on, in my car the driver side and passenger side is different. On the driver side the side with the slit goes to the bottom, but on the passenger side the side with the slit goes at the top. They only go on one way, so it's not hard to figure out.
Door trim, the stitching below the red stitches is the line you want to use. There is a small area the flat head will fit and the door trim pops right off with a little force. To put them back on, line the top up and it pops right in.
The trim around the shifter, take the shift knob off first. After that you want to grab both sides by the AC Controls and pull straight up then pull around the trim. This is where the phillips screwdriver comes in. To remove the traction control buttons and such, there is two phillips screws to remove. Pull the entire trim up and the shift boot will slide right off. Four phillips screws hold the shift boot on.
To put it back together, the shift boot only goes on one way. Put the 4 screws back on and slide the shift boot around the reverse lookout lever. A tip, don't pull it all the way down, it's hell to put it back on the lockout lever. Put the screws back in for the buttons. Line the trim up at the buttons and push all the way around and it pops back in place.
For the piece around the radio, start on the passenger side where the two pieces line up. Push up from the bottom and pull up a little from the bottom and follow it around to take off. Same concept for the one around the radio. Putting it on is simple as well, start on the radio side. Start from the top and push it in and it pops in place. Same on the other side.
That's pretty much it, not that hard. Easier than I had expected. Don't be scared to use a little force, I know I was because the pieces feel so flimsy.
[ame]http://youtu.be/Z4YhKxot73k[/ame]
dbrandt01 is offline   Reply With Quote
Old 03-01-2014, 08:34 PM   #2
CoupedUpSubie
Drives: 2013 BRZ Limited
A set of plastic trim levers is useful also. I want to say I bought a set for $15.
For the vent trim rings I recommend pulling the whole assembly. Stick a couple fingers through the flaps and pull, then pop the off by releasing the clips on the back.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 03-01-2014, 08:42 PM   #3
dbrandt01
Drives: none
I agree a screwdriver isn't the best, but in all honesty two screwdrivers is the only tool items I have. It's not something I keep.
The first vent ring, I didn't intend for it to fly off that way. I didn't think about taking the whole assembly out. I'll have to try that next time.
Old 03-01-2014, 10:17 PM   #4
CoupedUpSubie
It is very easy that way. I wrapped as much of the silver as I could with the vinyl used. I wish I had taken pictures of how I did everything.
Old 03-02-2014, 03:11 PM   #5
congee
congee's Avatar
Drives: SSM BRZ
Anyone know how to remove the center dash silver trims beside the ac controls?
congee is offline   Reply With Quote
Old 03-02-2014, 04:03 PM   #6
dbrandt01
Drives: none
http://www.ft86club.com/forums/showthread.php?t=13583
That should help you with them pieces.
Old 03-31-2014, 02:21 AM   #7
FrSnake
Resident Noob
FrSnake's Avatar
Drives: Satin White BRZ Limited
How about removing the steering wheel piece? Same concept, flat head to the bottom of the piece?
USAF2013 SWP BRZ Limited- CAI, Borla Cat-Back Exhaust
“Speed has never killed anyone, suddenly becoming stationary… That’s what gets you.” -Jeremy Clarkson
FrSnake is offline   Reply With Quote
Old 03-31-2014, 07:09 AM   #8
dbrandt01
Drives: none
@FrSnake
http://www.ft86club.com/forums/showp...87&postcount=2
That should help you. It involved taking the airbag and such out. Which is why I didn't do it..
Old 04-18-2014, 08:29 AM   #9
Frank5364
Frank5364's Avatar
Drives: 2014 Subaru BRZ white limited
How you remove the two middle small silver pillars just under neath the headunit also? Can you make a vid for this? Thanks bro btw great YouTube vid!
Frank5364 is offline   Reply With Quote
Old 04-18-2014, 09:52 AM   #10
dbrandt01
Drives: none
I included the link above to a post on this forum @Frank5364
Just involves taking more stuff out and I didn't have a need to remove them since the silver breaks it up inside instead of having too much red.
Old 04-18-2014, 10:31 AM   #11
Frank5364
Frank5364's Avatar
I might go black on that.
Interior trim trim clips (Dash Trim Panel) ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 4 08-11-2022 07:47 AM
Need help removing shifter trim spitz Cosmetic Modification (Interior/Exterior/Lighting) 10 09-28-2019 08:34 AM
DIY Request: Removing Side Fender Trim GH05T DIY (Do-It-Yourself) Guides 19 12-17-2017 02:11 AM
WTT interior silver FR-S trim for black trim. Panda Grahams Interior Parts (Incl. Lighting) 7 10-11-2013 07:35 PM
Removing interior trim dash panels ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 7 05-30-2012 09:20 AM
