Old 02-28-2014, 03:14 PM   #1
jakevernon405
jakevernon405's Avatar
Drives: 2014 Scion fr-s
hid brights question
What's goin on guys, ordering my hids today, but I had a quick thought before I put the order in. Being that my brights and running lights are the same bulb, When I swap those brights out will that have me running my brights all the time? Also will they be yellow all the time? Thanks.
2014 Fr-s
K&N drop filter
Perrin 2.5" catback
jakevernon405 is offline   Reply With Quote
Old 02-28-2014, 03:39 PM   #2
frslee
Just drive it
Drives: 13' FR-S
what are you talking about? Our cars have separate low and high beam. You'll be changing low beam only. Other bulb is for DRL/highbeam.
frslee is offline   Reply With Quote
Old 02-28-2014, 06:34 PM   #3
jakevernon405
I'm talking about the DRL/highbeam
2014 Fr-s
K&N drop filter
Perrin 2.5" catback
Old 02-28-2014, 07:18 PM   #4
speedrye
Drives: White
You don't install HIDs in the high beam light, just the low beam. If you do, you'll have to disable the DRL, otherwise the DRL's lower voltage will kill the ballast/bulb. You'll also lose function of your high beam to some extent since the bulb takes awhile to warm up when you turn it on.
speedrye is offline   Reply With Quote
Old 02-28-2014, 07:28 PM   #5
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
You're going to fry the ballast unless you disable the DRL. DRL uses a low voltage and/or PWM, not sure what the FRS uses.
Rayme is offline   Reply With Quote
Old 02-28-2014, 07:52 PM   #6
jakevernon405
Got it. How would I get that night whiter ( not doing the led bulb I still want a high beam)
2014 Fr-s
K&N drop filter
Perrin 2.5" catback
Old 02-28-2014, 08:13 PM   #7
OURO3OROS
Drives: 2013 Asphalt FR-S
You'll want to go with a "hyper white" or some such halogen bulb, like the Sylvania Silverstars.
OURO3OROS is offline   Reply With Quote
Old 02-28-2014, 10:03 PM   #8
mush
mush's Avatar
u can try this
http://www.vleds.com/led-headlights.html
Old 02-28-2014, 11:29 PM   #9
jakevernon405
Perfect man
2014 Fr-s
K&N drop filter
Perrin 2.5" catback
Question for the the 2014 Brz Nav Owners (BT Question) jbsali Electronics | Audio | NAV | Infotainment 3 07-16-2014 11:41 AM
FRS To BRZ Question BadMoon BRZ First-Gen (2012+) — General Topics 33 12-31-2013 09:24 PM
PnP HID kit question Jacob G. Cosmetic Modification (Interior/Exterior/Lighting) 4 02-23-2013 08:58 PM
E-85 Question J-Money Engine, Exhaust, Transmission 20 02-04-2013 10:11 PM
BEspoke question and rattle question bdanisi Electronics | Audio | NAV | Infotainment 2 01-30-2013 02:11 PM
