Old 02-28-2014, 12:52 PM   #1
varun
Drives: 2013 FRS
Will these fit & not rub? SSR 18x8.5 49+ offset on KW CS coilovers?
I would like to mount a set of SSR 18x8.5 wheels with a 49+ offset on a FRS with KW CS coilovers and lowered. Tires i'm thinking would be 245/40/18 but can be changed if this wont fit.
Will these rub with this offset? How would a 33+ offset be different and do I need something closer to that?
Thanks in advance.
varun is offline   Reply With Quote
Old 02-28-2014, 12:58 PM   #2
mackdaddytran
mackdaddytran's Avatar
Drives: Toyota Skyline Type-R
Wrong section, broseph.
But depending on how low you're running your coilovers - you shouldn't rub too much. That's a conservative setup
mackdaddytran is offline   Reply With Quote
Old 02-28-2014, 01:29 PM   #3
varun
Drives: 2013 FRS
I'm setting up the car for the track (road course) so no crazy drops but it will be low. And ideally would like to not rub at all!
Do I need to decrease the offset or will this be fine?
Old 03-01-2014, 01:12 PM   #4
varun
Drives: 2013 FRS
Any1?
Old 03-01-2014, 02:18 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Did you even bother using resources to help answer a question first?
http://www.ft86club.com/forums/showthread.php?t=7535
Old 03-01-2014, 03:19 PM   #6
varun
Drives: 2013 FRS
Yes I actually did an extensive search and read that guide, it gave me an idea of what i'm looking at but did not specifically answer my question.
Its an SSR 18x8.5 wheel with a 49+ offset thats a rare setup for 245/40/18 and im guessing the KW's will lower it 2 inches if not more, hence I'm unsure & skeptical..
Old 03-01-2014, 05:27 PM   #7
mav1178
mav1178's Avatar
coilovers will give you more clearance vs stock struts on the inside. You will be a very tight fit but it will fit.
-alex
Volk CE28N 18x8.5 5x100 +44 offset Jhon19lopez Wheels and Tires 3 08-09-2013 07:33 PM
FS: PacificNW - 18x8 Black Enkei Fujin w/ 40mm offset MyEvilMonkeys Wheels and Tires 1 06-14-2013 03:18 AM
What offset is legal? What offset provides most benefit? bdohazelnuts Tracking / Autocross / HPDE / Drifting 2 02-08-2013 01:32 PM
XXR 527 18X8.75 35 OFFSET - GOLD FINISH - BLOW-OUT-PRICES!!~!~! MIKE@MRTIRESOLUTIONS Wheels and Tires 1 12-12-2012 12:57 PM
18x8 37 offset kinryu Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-29-2012 04:29 PM
