Old 02-21-2014, 12:13 PM   #1
raytrix
Drives: Series 10 FR-S
18x10 +40 wide wheel up front?
Has anyone ran a spec close to 18x10 +40 up front? Are there rubbing issues with the tire rubbing the chassis at full lock? I'm looking into Volk ZE-40 and would love to obtain the same concave spoke design front to back. Face 3 concave is only on 18x10 +40 while the less concave is on the 18x9.5 +43 for 5x100. Looking to see if anyone here has feedback on a 10" wide wheel up front and what to look for in terms of rubbing issues and tire sizes to use.
raytrix is offline   Reply With Quote
Old 02-21-2014, 12:23 PM   #2
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
i've ran 18x10 + 44 with 3mm spacers and it was fine.
Jesse@JDLAutodesign is offline   Reply With Quote
Old 02-21-2014, 12:25 PM   #3
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
10"? Man if you're at any kind of low what size of stretched tire and crazy camber and fender pullin' would that require to fit and drive without issue???
Old 02-21-2014, 12:38 PM   #4
wparsons
wparsons's Avatar
On coilovers I assume? There's no way a 10" +41 (+44 and the 3mm spacer) fits with the stock struts/spring seats.
flickr
Old 02-21-2014, 12:39 PM   #5
Jesse@JDLAutodesign
yes coilovers
Old 02-21-2014, 12:46 PM   #6
Jesse@JDLAutodesign
275/35/18
Old 02-21-2014, 12:50 PM   #7
OICU812
Just a dude
OICU812's Avatar
ME = OFFICIALLY MIND BLOWN
What kind of camber is that done with? I mean by picture doesent seem to be any or very little and I guess I can't wrap my head around if you hit a bump while turning how that wouldn't rip a corner of the car a new ass?
Old 02-21-2014, 01:45 PM   #8
raytrix
Thanks for the feedback. My local shop has warned me of a potential issue where because the wheel has a higher offset where the wheel's inner clearance is closer to the chassis that when I turn the wheel at full lock, depending on the tire it might be touching the chassis and will rub. I just want to confirm this with a few people that has fitted something similar to the specs I posted up. 18x10 +40. Now if my offset was lower like 18x10 +25 I would have no issues at all with the tire hitting the chassis at full lock, instead now that the wheel shifted away from the chassis that at full lock I will be hitting the fender liner and have issues with clipping the fender edges. I currently running -2 camber all around and sitting on a set of Stance Pro Comp 2 coilovers.
Old 02-21-2014, 02:07 PM   #9
ilpad
ilpad's Avatar
Drives: 2013 - Scion FR-S in White"red"out.
I run 18x9.5 +38 with 255/35s with unrolled fenders and I have zero rub. Its close, but even under extreme driving I havent had a rub yet. Im probably going 265s on my next set of rubber.
ilpad is offline   Reply With Quote
Old 02-21-2014, 02:27 PM   #10
raytrix
My worry isn't the fenders, it's the inner chassis tub that you might rub at full lock.
Old 02-24-2014, 11:26 AM   #11
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Here is someone running 18x10 +38 all around...
http://www.ft86club.com/forums/showthread.php?t=38778
Old 02-24-2014, 07:45 PM   #12
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Also I run 18x10 +38 front and rear. With 245s, have plenty of clearance to step up in tire size too...
-1.5 camber front and rear... Check out my members gallery thread for pics.
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Wheel Directory: Work Meister S1R 18x10.0 +12 / 18x10.5 +17 larryw Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 41 01-16-2014 12:29 AM
Wheel Directory: CCW Classic 18x9.5 +33 / 18x10.0 +38 xxscaxx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 12-30-2013 10:41 PM
30mm wide fenders and 18x10 +44 ft86me Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 11-30-2013 04:55 PM
WTB: BRZ PS headlight, hood, front wide fenders, front bumper/ body kit Guildjs Want-To-Buy Requests 5 10-31-2013 08:35 PM
Wekfest Nj 2012 ... Our BRZ Showing off the wide 18x10 Setup RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 09-03-2012 06:36 PM
