| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: Series 10 FR-S
18x10 +40 wide wheel up front?
Has anyone ran a spec close to 18x10 +40 up front? Are there rubbing issues with the tire rubbing the chassis at full lock? I'm looking into Volk ZE-40 and would love to obtain the same concave spoke design front to back. Face 3 concave is only on 18x10 +40 while the less concave is on the 18x9.5 +43 for 5x100. Looking to see if anyone here has feedback on a 10" wide wheel up front and what to look for in terms of rubbing issues and tire sizes to use.
#2 |
Drives: 2013 Raven Black FRS
i've ran 18x10 + 44 with 3mm spacers and it was fine.
#3 |
Just a dude
Drives: Scion FR-S 2013
10"? Man if you're at any kind of low what size of stretched tire and crazy camber and fender pullin' would that require to fit and drive without issue???
#4 |
On coilovers I assume? There's no way a 10" +41 (+44 and the 3mm spacer) fits with the stock struts/spring seats.
#5 |
#6 |
#7 |
Just a dude
ME = OFFICIALLY MIND BLOWN
What kind of camber is that done with? I mean by picture doesent seem to be any or very little and I guess I can't wrap my head around if you hit a bump while turning how that wouldn't rip a corner of the car a new ass?
#8 |
Thanks for the feedback. My local shop has warned me of a potential issue where because the wheel has a higher offset where the wheel's inner clearance is closer to the chassis that when I turn the wheel at full lock, depending on the tire it might be touching the chassis and will rub. I just want to confirm this with a few people that has fitted something similar to the specs I posted up. 18x10 +40. Now if my offset was lower like 18x10 +25 I would have no issues at all with the tire hitting the chassis at full lock, instead now that the wheel shifted away from the chassis that at full lock I will be hitting the fender liner and have issues with clipping the fender edges. I currently running -2 camber all around and sitting on a set of Stance Pro Comp 2 coilovers.
#9 |
Drives: 2013 - Scion FR-S in White"red"out.
I run 18x9.5 +38 with 255/35s with unrolled fenders and I have zero rub. Its close, but even under extreme driving I havent had a rub yet. Im probably going 265s on my next set of rubber.
#10 |
My worry isn't the fenders, it's the inner chassis tub that you might rub at full lock.
#11 |
NW Region Moderator
Drives: FR-S No More
Here is someone running 18x10 +38 all around...
http://www.ft86club.com/forums/showthread.php?t=38778
#12 |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
Also I run 18x10 +38 front and rear. With 245s, have plenty of clearance to step up in tire size too...
-1.5 camber front and rear... Check out my members gallery thread for pics.
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
| Wheel Directory: Work Meister S1R 18x10.0 +12 / 18x10.5 +17 | larryw | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 41 | 01-16-2014 12:29 AM |
| Wheel Directory: CCW Classic 18x9.5 +33 / 18x10.0 +38 | xxscaxx | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 29 | 12-30-2013 10:41 PM |
| 30mm wide fenders and 18x10 +44 | ft86me | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 11-30-2013 04:55 PM |
| WTB: BRZ PS headlight, hood, front wide fenders, front bumper/ body kit | Guildjs | Want-To-Buy Requests | 5 | 10-31-2013 08:35 PM |
| Wekfest Nj 2012 ... Our BRZ Showing off the wide 18x10 Setup | RavSpec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 09-03-2012 06:36 PM |
