Old 02-19-2014, 01:55 AM   #1
martinEZ
martinEZ's Avatar
Exclamation Uneven Exhaust Tips!!
The has to be a simple solution to this problem but I can't find one.
I just installed my Takeda Catback exhaust on my BRZ and the install was relatively easy. But I've noticed that my right side exhaust tip is perfectly centered, but the left side is hanging high left. I've checked the hangers and everything seems legit.
I can't be the first person to get uneven ends. Any help is appreciated.
martinEZ is offline   Reply With Quote
Old 02-19-2014, 08:10 AM   #2
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
I used extra long hangers on my j2 catback, and had to use a combination of extra long and oem hangers to get it to hang right.
86-tundra is offline   Reply With Quote
Old 02-19-2014, 10:55 AM   #3
EvilBeaverFace
Not trying to be a ****
EvilBeaverFace's Avatar
Drives: BRZ - 6MT - GBS
try loosening the connection between the mid pipe and front pipe, adjusting it and then re-tightening it?
EvilBeaverFace is offline   Reply With Quote
Old 02-19-2014, 12:22 PM   #4
humfrz
Stick a piece of pipe in the end of the offending exhaust tip, heat up the tail pipe with a torch, then bend the tail pipe to where you want it.
Well, that used to work back in the day .....
humfrz
Old 02-20-2014, 12:29 AM   #5
disconnected
disconnected's Avatar
sometimes my tip hangs to the right, and other times to the left... oh, hah were talking about exhaust.. nvm.
I had uneven tips when installing my perrin cbe, I fixed it by loosening up the joints at the muffler/s-pipe and at the s-pipe/mid-pipe, then gently pulling my tip back and forth until I was satisfied... before re-tightening the joints. It worked.
disconnected is offline   Reply With Quote
Old 02-20-2014, 07:49 PM   #6
martinEZ
martinEZ's Avatar
Thumbs up
Thanks for all the input guys. I ended up taking it to my local shop and the guy charged me fifteen bucks to torch the end and bend it into alignment. It most likely bent during shipping and he fixed it really good. Other than that, apparently one of the tips was welded on at an incorrect pitch so if you really really look for it you can see one tip tilted counter clockwise. But at a glance, hell even an extended look you can hardly see anything. I'll post some pics soon if the demand is there...
Old 02-21-2014, 01:37 PM   #7
CodyFRS
CodyFRS's Avatar
Drives: Asphalt FRS
You should see the cut job on my tips. Looks like someone took a hacksaw to cut the pipes and then a fingernail filer for 5 seconds over them to sand it down. Yes, also a J2 exhaust, let me tell you about quality hahahahaha Biggest mistake buying knockoff exhaust.
CodyFRS is offline   Reply With Quote
brz, exhaust, install, takeda, tips
Uneven steering assistance? koevasi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 01-14-2014 09:06 AM
Help! Jumpy/Uneven Acceleration ZackZ Scion FR-S / Toyota 86 GT86 General Forum 13 09-22-2013 12:42 PM
uneven engine vibration at idle whtchocla7e Issues | Warranty | Recalls / TSB 17 08-07-2013 09:21 PM
WTB: DC Exhaust Tips or Other Tips Xdragonxb0i Engine, Exhaust, Bolt-Ons 2 05-10-2013 06:36 AM
Exhaust tips rawbz Cosmetic Modification (Interior/Exterior/Lighting) 37 01-19-2013 08:12 PM
